1 members (60steve), 71 guests, and 4 robots.
Topics128,181
Posts1,057,152
Members48,464
Ok guys. I have a Tilt Cab 50 series chevy. Factory front brake drums are Dayton 120100. The last place you could buy them looks to be Napa. Made by Gunite under part number 3285. Dayton, Gunite, Meritor, Webb, have all obsoleted the drums. I even asked to buy an old pattern and cast and machine my own. All patterns from those companies have been destroyed. How does brake drum relining work?
Southeast Oklahoma
It might help if we knew what year your truck is. We have discussed resurfacing drums before but I don’t remember the outcome. Try our search function.
3B Offline
Hy BowtieMan, welcome, please remember to tell us the year of the truck you are searching for parts for, also the capacity of the front axle if you know it. Alternatively the diameter and width of the braking surface and the number of holes in the mounting surface of the drum, hope that helps.
I believe it's a 7k front axle. Drum is 15x3. Truck is a 67 model. 10x8 3/4 bolt pattern
Southeast Oklahoma
3B Offline
Hy BowtieMan, the GM p/n is 3996775, as you said Napa p/n TWD 3285. contact member 54 3600, he performs dealership searches for N.O.S. parts, send him a PM and ask him to search for us. Are you sure there are no more at Napa?
Called my local Napa. They said it still pulls up but in his system it says none available.
Southeast Oklahoma
' Offline
I searched for Brake Drum GM # 3996775
OLD GM # 3789918 .
No luck with those two part #'s .
Just for the heck of it try these guys .
https://www.lyonstruckandtrailer.com/
https://www.napaonline.com/en/p/TWR3285
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
https://www.pscpartsstore.com/en/brake-drums-2
Try this site. Maybe something matches or comes close enough to make work. Did't find an application guide, but they show the dimensions.
BaconFarms
1948 GMC 2 Ton
1958 GMC 370-8
1965 GMC 5000
1970 Chevrolet C50
https://deltatiresaleandservice.com/services/brake-drum-installation/
Got to log in to see what they got, but they got a number to call?
BaconFarms
1948 GMC 2 Ton
1958 GMC 370-8
1965 GMC 5000
1970 Chevrolet C50
Call these guys. If they cant fix you up, they probably know who can.
They cut a big truck drum near the end of the video..
I did run one of the flywheel grinders back in the day when I worked at a parts store. Fun..
BaconFarms
1948 GMC 2 Ton
1958 GMC 370-8
1965 GMC 5000
1970 Chevrolet C50
Crusing in the Passing Lane
Find a later truck with the same bolt pattern.
Ed
3B Offline
Hy BowtieMan, just a thought have you had the drums checked with a micrometer, it seems to me these drums could be turned up to .090 oversize. I will try and verify that as I'm operating on dubious memory cells.
3B Offline
Hy BowtieMan, okay I have verified "Drums with standard diameter over 14" can be machined up to.080" oversize." I hope your drums are still turnable.
Found at least 4 drums at a big truck salvage in Kansas. I think ill buy them all!
Southeast Oklahoma
That would be enough to last 4 lifetimes...lol!
Make sure they are still within spec and not just junk.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
If you didn't buy the used ones, I have one Dayton 120100 new old stock in my warehouse. Sorry we did not see your posts when they were current, we just don't find the time to stay up on the Internet. My wife and I have a bunch of NOS GM stuff for the 'big bolts'!
Tom&Kathy
Hello Tom:
I saw your post and was curious as to what type of items you have for big bolts. I’m alway on the lookout for parts for my truck.
Thank you for your time.
Regards,
Phil Stewart
Please use the Swap Meet section for buying/selling parts, or private messages as applicable.
Not the general forums.
