2 members (Hotrod Lincoln, greenie-reddy), 96 guests, and 2 robots.
Topics128,049
Posts1,055,741
#127818 08/23/2007 3:12 AM
Apprentice
Apprentice
Hi all,
My '46 half tons frame seems to be out of alinement. I believe the rear passenger side must have taken a hit sometime in its life. What is the best way to check for "squareness" and how do you "true" the frame back up? Thanks.
#127819 08/23/2007 3:22 AM
Metricnut, my '51 half ton seemed to sag on one side so I took it to a spring shop, thinking I could have the springs re-arced. They found what they thought was a bent frame causing the problem. I don't know where in AZ you are located but the spring shop recommended Gilbert Collision (in Gilbert, AZ, of course). I took the truck there and they pulled the bed, put the truck on their hydraulic frame staightener. Now, the truck sits nice and pretty. They thought the truck had been hit on the right side in the past, probably prompting the restoration it had 15-17 years ago by a PO. I recall I paid $350-400 dollars but I thought it was well worth it for such a serious ailment.
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
#127820 08/23/2007 11:47 PM
Apprentice
Apprentice
Cool, thanks for the lead. I'm in Sedona & would need to figure a way to haul the frame down. Thanks!
#127821 08/24/2007 12:09 AM
Ex Hall Monitor
Ex Hall Monitor
Good advise! Bent frame? Go to a frame shop (and I don't mean the kind you hang on the wall grin ).
#127822 09/02/2007 4:54 AM
to measure for squareness.. measure end to end on both frame rails, and then from the spring hangers on one side to the spring hangers on the other side (measure in an X)..
my frame is bent just a touch, the right side frame rail is 1/8 of an inch shorter than the left side.
When i installed my IFS, i split the difference by 1/16 of an inch,,, the truck drives straight down the road, doesnt wander or pull..
Another quality post.
Real Trucks Rattle
#127823 09/06/2007 3:54 AM
I suppose it would have been smart to have measured and checked my frame for correctness when it was bare. That would be a great suggestion to all who have a empty frame.
~Jim
