6 members (Hotrod Lincoln, 48ed56pam, Ponchogl, lumbersawyer, MickeyP, Bill Hanlon), 136 guests, and 2 robots.
Topics128,081
Posts1,056,073
Members48,434
I know this has popped up in several post as the first suggestion when trouble shooting but it is worth mentioning again. My 54 is original. It still needs a lot of work. There is still a lot of hidden rust. As a result of the rust at a lot of the body connection points I do not have a good ground throughout the body. As a result I have experienced various electrical issues. My tip, if you have any electrical issue the first test should be to make sure you have a good connection to ground. I was having an issue with my fuel gauge. It started working after I bypassed the ground wire to the cab and took the ground directly to the frame. I also installed a new set of parking lights. Neither the parking lights or the turn signals worked . I tested with my meter. No or low voltage at the socket when using the grill as my ground source. I took a jumper to a good ground source and I then had a good 12v circuit and working lights. I have selected some random locations throughout the truck and ran jumpers wires back to the frame to ensure I have a good ground through all the various body parts.
Dave from Northern Kentucky
My 54 3100
Q
Q Offline
A very good reminder, good ground connections are so crucial, and easily overlooked cause it's so basic! Thanks
H Online: Content
Grounds are the electrical equivalent to the sewer in a municipal water system. If the bathtub (or the toilet) can't drain, all the new, clean pipes and good water pressure in the world won't get the job done!
24601
Another good conversation gone down the toilet ... dance
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Moderator
Moderator
2 Offline
John and Jerry, you never cease to amaze me with your wet humor.
Back on topic.
I had a Jeep years ago and the starter got to turning slow.
Tried a new starter, good battery and turned over even slower and then quit.
Check that the starter was grounded to the engine and frame.
It was not.
Bolted a ground wire from the starter to the block. Problem solved and the starter turned great.
Later that year I had to pull the tranny (don't remember why) and found the bell housing degraded where it bolted to the block.
Bell housing is aluminium and of course the engine block is steel.
Galvanic Corrosion had occurred and lost the electrical connection between the bell housing and block.
https://en.wikipedia.org/wiki/Galvanic_corrosion
Good reminder to check the grounds first.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
When I wire up cars I treat all componets like they are mounted to a fiberglass body. Which means that everything gets a ground circuit added to it. I know that it sounds overkill but between fresh paint, gaskets and then the beginning of corrosion it will always have a ground. It really isn't as tough as you think. I install a ground block inside the car for everything to go back to, Under the hood I install a ground junction that every thing goes to. The rear for lights every thing goes to a terminal block that has a common ground terminal.
That is what am considering doing. Adding a ground block to make it easy.
My 54 3100
H Online: Content
Well you could do it the British way- - - - -run hot wires to everything, insulate them, and then put all the switches in the ground circuit. It takes twice as much wire that way, and doubles the chances of getting a bad connection!
I recently chopped up a junk Nissan Sentra so that the scrap metal yard would accept it without a title. I was surprised of the number of junction blocks with 5 or more little ground wires attached to them.
