Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Otto Skorzeny, FAST55, Dakota Bob), 119 guests, and 3 robots.
Topics128,282
Posts1,058,490
Members48,490
Z
Z Offline
I've been working on my rebuilt 57 235 and have run into a snag. I have a short shaft water pump and pulley from Classic Parts and stock harmonic balancer. Either the balancer is pressed on too far or the pump some how isn't right, because the water pump pulley groove is about 1/4" closer toward the radiator than the balancer. Any thoughts? Is it possible for a balancer to be pressed on too far, or could something else be off? I received the engine in pieces so I don't know much about how it was before it was taken apart. The water pump is new.
The "short shaft" water pump is just one that's had its hub pressed back to supposedly align with the single groove in the older balancer. Take the back plate off the pump and push the hub back carefully until the grooves line up. Then cut a little more off the pump shaft if necessary. A much better idea would be to get the pump relocation plate Pre 68 Dave sells and install a 216 style water pump. Then the vertical position of the fan will be right as well.
