3 members (Steelonsteel, Woogeroo, klhansen), 154 guests, and 3 robots.
Topics128,186
Posts1,057,317
Members48,469
1 Offline
I recently replace the brake lines and then the wheel cylinders began leaking. Replaced the 3 that were leaking. The 2 rears are leaking now where the banjo bolt treads into the wheel cylinder. Each rear drum is wet inside and that's the only spot I believe it's coming from. It's a very slow seep but I can see it on the tire in the morning. I've tightened that bolt to the point I don't want to break it. Just replace the banjo bolt or should I be checking something else? Frustrated...
On the same subject. I'm really struggling getting the truck to brake straight. It pulls hard to the front drivers wheel. I've adjusted the brakes and they work good for a couple days - then starts pulling again. About to give up and order front discs.
Mike
1952 -3100 with '52 235 Iowa farm truck "Cecil"
Today’s parts quality is pretty bad. I have seen folks go through 3-4 wheel cylinders before getting one that doesn’t leak. Replacing the banjo bolt is by far the least expensive thing to try but chances are it won’t fix the problem. 🛠
make sure you're not getting the cheaper Chinese cylinders .... the pulling can also be caused by the leaky rears
Make sure you get some brake clean and clean the shoes and drums or else it will still pull to the side like a banshee.
I recently had a bad wheel cylinder new out of the box too.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Crusing in the Passing Lane
The Cu washers on the banjo bolt can be anealed to make them soft again which would be worth doing. Heat to red, let cool
Ed
1 Offline
I bought them at Napa - and the are made in China. Suggestions on where to buy?
Mike
I found NAPA here could get better quality ones if asked, try them and specify - for more money of course
It sounds like a problem with the copper washers to me. If you don't have new ones then you need to anneal the old ones as above. That has nothing to do with the quality of the cylinder.
1951 1 Ton Completed
Never, ever re-use a copper seal washer. They are a one-time use item and it's nearly impossible to get a used one to seal again.
1 Offline
Update --- pulled it all apart. Cleaned the fittings, banjo bolts, and found I did reuse one copper washer on each. Replaced all with new and haven't seen a drop in 2 days! Thanks all for the help and education!
Mike
