Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
11 members (dt235sd, BC59, cmayna, 66flea, Bill Hanlon, Otto Skorzeny, greenie-reddy, TexasFarmTruck, DennisM, Thom75, 1 invisible), 187 guests, and 4 robots.
Topics128,282
Posts1,058,497
Members48,490
#12770 12/13/2002 4:11 PM
Junior Member
Junior Member
frown My engine has been running very rough for a little while. Well last night I took off the head and 4 exhaust valves are sunk into the head! No wonder it ran like crap!!! It's now at the machine shop to see if anything can be done, but has anyone had this happen to them?
And if so, what did you do,if anything can be done, to fix the problem? The engine is a stock setup.
LET'S GO ISLANDERS!!!
1963 Chevy 1/2 ton fleetside w/'65 Pontiac 215 6cyl.(not the OHC engine!)
1950 Ford 2 door sedan-project
#12771 12/13/2002 5:20 PM
I would think any good machine shop should be able to machine new valve seats (hardened) and valve guides into the heads. I just had this done to my heads. It ain't cheap though - new seats, guides, and valves probably around $300-$400.
72 Sierra Grande - Maych
Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
#12772 12/13/2002 5:42 PM
I've got 3 or 4 heads in the same condition as yours. It's called unleaded gas syndrone. JohnnyP is right the machine shop will fix it. Replace seats.
Regards,
Larry
I don't own a vehicle that isn't old enough to drink.
#12773 12/13/2002 9:18 PM
They're right, a head this worn calls for 6 new exhaust seats, all new valves, new guides, retainers, locks, springs, seals, head milling, the works. Cost me $350 back in '97 when I had it done.
Make sure that the machinist sets the spring installed height and spring pressures correctly. Don't just shim up the valvespring if the seat pressures are low. Replace the springs if weak.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#12774 12/14/2002 10:09 PM
sounds like my 50 chev(216) engine,,,I burn unleaded in it too,,my truck sounds like your 63 does,,,,i didn't take the head off yet,,i'll try a compression test first,but the way it sounds,,i probably have some bad valves,,,just my 2 cents worth frown eek frown
#12775 12/15/2002 2:58 AM
Should I put some lead substitute into the tank, before I start up my rebuild engine
Fritz Peyerl
Turner valley, Alberta
http://www.badmileage.com
#12776 12/15/2002 3:10 AM
According to the guy that worked on my head, it only really matters if you put on a fair amount of miles. I didn't have my seats replaced.
1951 1 Ton Completed
