| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12770 12/13/2002 4:11 PM | Joined: Oct 2002 Posts: 29 Junior Member | | Junior Member Joined: Oct 2002 Posts: 29 |  My engine has been running very rough for a little while. Well last night I took off the head and 4 exhaust valves are sunk into the head! No wonder it ran like crap!!! It's now at the machine shop to see if anything can be done, but has anyone had this happen to them? And if so, what did you do,if anything can be done, to fix the problem? The engine is a stock setup.
LET'S GO ISLANDERS!!!
1963 Chevy 1/2 ton fleetside w/'65 Pontiac 215 6cyl.(not the OHC engine!) 1950 Ford 2 door sedan-project
#12771 12/13/2002 5:20 PM | Joined: Jul 2002 Posts: 59 Member | | Member Joined: Jul 2002 Posts: 59 | I would think any good machine shop should be able to machine new valve seats (hardened) and valve guides into the heads. I just had this done to my heads. It ain't cheap though - new seats, guides, and valves probably around $300-$400. 72 Sierra Grande - Maych Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
#12772 12/13/2002 5:42 PM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | I've got 3 or 4 heads in the same condition as yours. It's called unleaded gas syndrone. JohnnyP is right the machine shop will fix it. Replace seats.
Regards, Larry
I don't own a vehicle that isn't old enough to drink. | | |
#12773 12/13/2002 9:18 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | They're right, a head this worn calls for 6 new exhaust seats, all new valves, new guides, retainers, locks, springs, seals, head milling, the works. Cost me $350 back in '97 when I had it done. Make sure that the machinist sets the spring installed height and spring pressures correctly. Don't just shim up the valvespring if the seat pressures are low. Replace the springs if weak.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#12774 12/14/2002 10:09 PM | Joined: Aug 2002 Posts: 117 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 117 | sounds like my 50 chev(216) engine,,,I burn unleaded in it too,,my truck sounds like your 63 does,,,,i didn't take the head off yet,,i'll try a compression test first,but the way it sounds,,i probably have some bad valves,,,just my 2 cents worth  | | |
#12775 12/15/2002 2:58 AM | Joined: Jul 2002 Posts: 91 Member | | Member Joined: Jul 2002 Posts: 91 | Should I put some lead substitute into the tank, before I start up my rebuild engine | | |
#12776 12/15/2002 3:10 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | According to the guy that worked on my head, it only really matters if you put on a fair amount of miles. I didn't have my seats replaced. | | |
