9 members (klhansen, rfs56trk, Bill Hanlon, 1955 1 Series, DHedrick, Otto Skorzeny, 39Master85, greenie-reddy, Peggy M),
136
Mod | | | Forums66 Topics128,087 Posts1,056,399 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | What is the name of the channel that the bottom of the glass sits in which is attached to the end of the window regulator? My passenger side door has it but not the drivers side. I hope they're available new?
Thank you, | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | On the AD Ron, its the lower sash. Taint seen them in any catalogs. Denny G
Denny G Sandwich, IL
| | | | | Joined: Mar 2000 Posts: 1,182 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,182 | what are you referring to? The metal channel that the door glass sits in? I haven't seen those available anywhere. I think you'd have to either buy a new window with the channel (expensive) or find a door you can scavenge for parts.
You might consider posting a parts wanted ad in the Swap Meet. It's possible somebody would have a door glass that's broken that they'd sell you and you could use the channel from that on yours. | | | | | Joined: Jul 2004 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 78 | I found mine in the bottom of the door after 2 weeks of trying to find used ones. Just a thought. Good Luck Steve | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | Seen a few on Ebay now and then... under vintage auto parts.
Mike | | | | | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | Marty, I fired off a PM to ya. | | |
