4 members (Hotrod Lincoln, Southerntruck, Rich'sToys, 1 invisible), 83 guests, and 3 robots.
Topics128,090
Posts1,056,373
Members48,442
#127695 08/07/2007 6:35 PM
What is the name of the channel that the bottom of the glass sits in which is attached to the end of the window regulator? My passenger side door has it but not the drivers side. I hope they're available new?
Thank you,
#127696 08/07/2007 8:56 PM
On the AD Ron, its the lower sash. Taint seen them in any catalogs.
Denny G
Denny G
Sandwich, IL
#127697 08/07/2007 9:22 PM
Red dot, center of chest ...
what are you referring to? The metal channel that the door glass sits in? I haven't seen those available anywhere. I think you'd have to either buy a new window with the channel (expensive) or find a door you can scavenge for parts.
You might consider posting a parts wanted ad in the Swap Meet. It's possible somebody would have a door glass that's broken that they'd sell you and you could use the channel from that on yours.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
#127698 08/07/2007 10:40 PM
I found mine in the bottom of the door after 2 weeks of trying to find used ones. Just a thought.
Good Luck
Steve
#127699 08/08/2007 1:57 AM
Seen a few on Ebay now and then... under vintage auto parts.
Mike
#127700 08/08/2007 3:07 AM
Mumm,,,I sent you a P.M.
#127701 08/08/2007 7:34 PM
Marty, I fired off a PM to ya.
