1 members (RLB),
215
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | If it's possible, how would I wire an ammeter in a charging system that has been converted to 12V and uses a 1 wire alternator? This is for my '48 GMC that had already been converted before I got it and is also using negative ground. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | Thank you Tim! Just what I needed. | | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | ....Tim, just what I needed but electrically challenged as I am I need a little more information. The diagram you provided shows one direct connection from the Positive + battery post to the starter and another direct connection to the ammeter. Does the second connection have to be run separately or can it run from the starter to the ammeter? Thanks in advance! Jim | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Excellent question, Jim
12v negative ground.
You can run a big "+ power lead" cable to the starter post, and the heavy wire from starter post to the ammeter.
Some people have taken the guts out of the voltage regulator, and then run the heavy-wire from the starter to a post on the voltage regulator box, and the heavy-wire from the voltage regulator box to the ammeter. That is the "neat-looking solution", using original wires..
Before I read that idea, I use a bolt/nut connection near the old voltage regulator and carefully/thoroughly wrapped it with electrical tape.
| | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | I like the gutless voltage regulator idea. That would look nice Another old part I can try to find. It's funny but the previous owner went to a lot of effort to modernize the electrical system while I'm trying to do just the opposite. | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | I use the gutted voltage regulator trick as well. Nice tip I learned in here a while back. Maybe from Tim.
