4 members (Hotrod Lincoln, Deegs53, Jims46, Gray_Ghost), 256 guests, and 0 robots.
Topics128,088
Posts1,056,114
Members48,434
#1276711 08/17/2018 10:48 PM
If it's possible, how would I wire an ammeter in a charging system that has been converted to 12V and uses a 1 wire alternator? This is for my '48 GMC that had already been converted before I got it and is also using negative ground.
Thank you Tim! Just what I needed.
....Tim, just what I needed but electrically challenged as I am I need a little more information. The diagram you provided shows one direct connection from the Positive + battery post to the starter and another direct connection to the ammeter. Does the second connection have to be run separately or can it run from the starter to the ammeter? Thanks in advance! Jim
Excellent question, Jim
12v negative ground.
You can run a big "+ power lead" cable to the starter post, and the heavy wire from starter post to the ammeter.
Some people have taken the guts out of the voltage regulator, and then run the heavy-wire from the starter to a post on the voltage regulator box, and the heavy-wire from the voltage regulator box to the ammeter. That is the "neat-looking solution", using original wires..
Before I read that idea, I use a bolt/nut connection near the old voltage regulator and carefully/thoroughly wrapped it with electrical tape.
I like the gutless voltage regulator idea. That would look nice Another old part I can try to find. It's funny but the previous owner went to a lot of effort to modernize the electrical system while I'm trying to do just the opposite.
I use the gutted voltage regulator trick as well. Nice tip I learned in here a while back. Maybe from Tim.
