3 members (60steve, TexasA&M48Truck, Wayne67vert), 78 guests, and 2 robots.
Topics128,212
Posts1,057,463
Members48,471
so I've been making all these Grand plans to change over to Bendix Brakes in my 1950 however when I crawled under it today I noticed that it already has Bendix brakes. Has anybody heard of perhaps a mid-year switch it is a GMC by the way.
1950 GMC 1/2 Ton Long Box
228-Zenith carb- SM420-bendix brakes
Maybe someone put a '50 cab on a '51-'53 frame. If not, they at the very least, swapped torque tube rear ends and front baking plates.
My 50 had huck in front and bendix on rear
Dad bought the truck in early 70’s.
No telling what was done to it before he got it.
What the the Vehicle Serial Number/ID?
What is then block date casting code (is the engine/block original)?
If you do not know where to find it, let us know - someone will post a photo.
What is the engine serial number (pressed into the block to the rear of where distributor goes into the bloock
http://www.oldgmctrucks.com/page0010.html
https://oldgmctrucks.infopop.cc/eve/forums/a/tpc/f/462107036/m/1421093432
https://oldgmctrucks.infopop.cc/eve/forums/a/tpc/f/462107036/m/71520754563
Most likely they would have switched when the old-style "ran-out".
The engine number is A228302917
The cab serial number FC 102 106718
It's a half ton long box on a half ton long box frame,. I would be surprised if a person could find a new half ton long box frame to put a half ton long box cab onto. As from what I understand they have some long box GMC was fairly rare.
