5 members (Hotrod Lincoln, Hanks custodian, Gdads51, Gray_Ghost, Maybellene), 80 guests, and 3 robots.
Topics128,066
Posts1,055,871
Members48,428
#127592 07/31/2007 12:59 AM
Junior Member
Junior Member
My winter project for my '57 stepside is repainting the frame. It was last painted about 15 years ago, primered and then gloss black on bare surfaces, and it's ready for a new coat.
Since I intend to do the job with everything other than wheels installed, prep will be light sanding, degrease and prep cleaner on exposed surfaces. According to the POR-15 people, that rules them out and I'm seeking advice on what paint to use. I've seen Rust Bullet BlackShell protective coating advertised and was wondering if anyone has any comments on that product or other recommendations.
Any advice greatly appreciated.
#127593 07/31/2007 7:55 AM
hemerite holds up good and looks almost ceramic
#127594 07/31/2007 11:34 AM
Welcome to the "Bolt". In the near future, I'll be doing the same to my frame. Where you'll be doing light sanding, I'm gonna sandblast mine. Other then that, pretty much the same as what you're doing. Question is: Why does it rule out POR-15? I've never used POR-15, mainly Zero-Rust. Sounds like what you're doing to the frame is perfect prep for the stuff. Just curious.
#127595 07/31/2007 5:18 PM
Junior Member
Junior Member
Quote
I called their tech line and was informed that POR-15 is most suitable for bare or rusted metal. I don't plan to sand it back to bare metal.
#127596 07/31/2007 5:23 PM
Junior Member
Junior Member
Quote
Thanks. I looked at it and the price is certainly right when compared to other specialty coatings.
#127597 08/01/2007 11:30 AM
OK, I gotcha now. That makes sense.
#127598 08/01/2007 1:14 PM
RUSTOLEUM !
1952 Chevy Shortbed
Photos in Photobucket
#127599 08/01/2007 2:38 PM
Zero Rust!
