2 members (55shaker, Paul_WNC),
75
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,035 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | I need to do a re-paint of the lower half of my '52 Suburban. I know little or nothing about re-paints. I've read that I should go over the area to be re-painted with 600 grit paper. Should I then prime and wet sand or can I spray right over the old finish? Knowledge is a terrible thing not to have! (P.S. the old finish is base/clear). | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | It depends on why you are repainting it. Is the clear peeling? Does the paint have chips or scratches in it? If you have rust coming through then you need more than sanding & paint. Give us a little more info on why you are repainting it. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | I have strange situation...I either have primer bleed through or more likely bondo bleed. The truck had a urethane yellow/tan primer and was painted an off white (base/clear). Three coats base (Dupont Chroma Color) and three coats clear. The paint was fine for about three months and then I started to notice light yellow blotches on the hood and then on the cowl (top & sides). The rest of the truck is fine, The blotches did not bleed through the clear. My plan is to paint the bottom half of the Burb Mariner Blue...probably with a single stage. | | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | steveg ,let's get something straight.In your first post you mention lower half of your burb,and in your second post you say (light yellow blotches on the hood,cowl,top and sides.is it just me? but that sounds like a fair portion of the whole rig!and when you say lower do you mean from the window line down ,or the first foot of the bottom.Who painted it? if it was not you ,take it back to who did! | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | I can't go back! The description "cowl, top and sides" describes(poorly,I guess) the whole cowl section only, from the front doors forward. I need to paint from the beltline down on the whole truck. | | | | | Joined: Jan 2007 Posts: 116 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 116 | what does cause them spots? my firebird has some
LEWIS
| | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Possibly improperly cured bondo or fiberglass. I did bodywork for my father 20 years ago. The filler never fully hardened and it sucked the paint off the furface. Took about 8 months in my case before anything looked wrong.
Keith | | |
