| | | Forums66 Topics128,042 Posts1,055,601 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 21 New Guy | | New Guy Joined: Mar 2006 Posts: 21 | I'm trying to weld both Rocker step plate combos on my 57 truck but there is a one inch gap between it and where it is suppose to meet the rear cab corner panel. The part supplier says its the right part? Someone please help! | | | | | Joined: Mar 2007 Posts: 30 Apprentice | | Apprentice Joined: Mar 2007 Posts: 30 | You can go to my site (58 chevy truck) and check out my step and rocker panel. I hope this helps. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the rocker piece should have a gap, there's a break there, it doesn't get welded to the back cab rocker molding ... but not an inch - if the step itself is an inch short of the door opening, I'd guess yer opening is messed up - how does the door fit?
AFAIK that combo piece is only made by one supplier, and ones I've seen and used fit fine, like mkabwe's appears to
Bill | | | | | Joined: Mar 2007 Posts: 30 Apprentice | | Apprentice Joined: Mar 2007 Posts: 30 | Yeah mine fit fine and I did weld mine where the cab and the rocker meet. I just thought it looked cleaner that way. | | |
