5 members (Rusted Nut, Southerntruck, MickeyP, mick53, Dennys28), 102 guests, and 3 robots.
Topics128,043
Posts1,055,611
I'm trying to weld both Rocker step plate combos on my 57 truck but there is a one inch gap between it and where it is suppose to meet the rear cab corner panel. The part supplier says its the right part? Someone please help!
Apprentice
Apprentice
You can go to my site (58 chevy truck) and check out my step and rocker panel. I hope this helps.
the rocker piece should have a gap, there's a break there, it doesn't get welded to the back cab rocker molding ... but not an inch - if the step itself is an inch short of the door opening, I'd guess yer opening is messed up - how does the door fit?
AFAIK that combo piece is only made by one supplier, and ones I've seen and used fit fine, like mkabwe's appears to
Apprentice
Apprentice
Yeah mine fit fine and I did weld mine where the cab and the rocker meet. I just thought it looked cleaner that way.
