7 members (Ribside, BarryP, Ol' Red, Donf, Rusted Nut, TomGMC, 3B), 95 guests, and 2 robots.
Topics128,134
Posts1,056,738
Members48,454
Good Friday evening fellow bolters!!
Before I set the fresh 235 back in the 54, I bought all new motor mounts from Jim Carter in Independence. The sleeves in my old motor mounts are shot and it's a shame that they are not offered to go along with the rear mounts because after seeing mine, I can't imagine any others are re-usable.
I was wondering if anyone knows of a source for the sleeves. I looked at a section of small pipe today at the local farm store and the ID looks ok (1/2 inch), but the OD is just slightly bigger than my old sleeves and I am afraid the pipe won't fit the hole in the bottom half of the mount.
Thanks!!
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
7
7 Offline
Would electrical conduit be a better fit? Might be a little on the light side.
Not sure about that. Haven't thought about conduit.
Riding in the Passing Lane
The tube doesnot go through the hole in the lower mount. It bottoms in the mount to serve as a spacer.
George
1972 Chevy c10 Cheyenne Super
George
Good evening George,
So the crossmember must be thick enough that it spaces the 2 halves out. I haven't test fit the bottom half yet. The pipe I found today may work then. I figure the pipe serves basically as a limiter so when you torque the bolt down, it don't mash the mount.
Thank you!!
The mount spacer/sleeve needs to be the correct OD as it rides in the cross member hole to keep the engine from moving forward or backwards (like a centering/alignment pin).
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
' Offline
Kevin , I bought this complete GM NOS motor mount kit back in 2008 .
PIC
https://s26.postimg.cc/qktgvsae1/GM_NOS_MOTOR_MOUNT_KIT_3760997_b.jpg
The sleeves as you call them are called SPACERS in the parts manual.
The original part # GM 3705449 superseded to GM # 3769338
Dan's GM Obsolete
Chinook , Montana
phone : 406 - 357 - 2615
Dan's has ( 20 ) GM # 3769338 SPACERS in stock
Locks are available on ebay - GM # 3763763
PIC
https://s26.postimg.cc/55fkxx5dl/Rear_Motor_Mount_Nut_Locks_Second_Design.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
