| | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | So my 54 3100 PU is in many pieces and the paint just about ready to be applied. Wanted to get ahead of things before all the painted parts come back to be assembled to make a truck. One task was to change out a wrong size water pump from 5/8 to 3/8 pulley.
So my question is, is the fan pulling air through the radiator (I assume so) and if you are facing the fan from the front, is it rotating clockwise as you face towards the engine?
thanks for the help | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 |
thanks for the help[/quote] Yes. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | hi, i do believe that the fan is turning clock wise when looking at it from the front of the engine. here is my reasoning, the fan turns the same direction as the engine when i use the crank to start the engine one must turn that crank clockwise, aka push down on driver side, or the preferred method, heave up on the passenger side. you can't turn the engine backwards with the crank as it is locks into the front pulley one way only. make sense? i think i make sense most days... but i could be poor at explaining stuff sometimes. -s | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If you're concerned about getting the fan on backward it can't happen. You can turn a radial style fan blade around and the blade pitch is still in the same direction. A lot of people don't believe that until they actually try it. I've not tried to mount one backward but there would likely be clearance & mounting issues if you tried it anyway.
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | The only reverse-rotation fan and water pump setups I'm aware of are on some serpentine belt systems where the fan and water pump turn opposite crankshaft rotation. All the fans on stovebolts turn clockwise when viewed from the front. Now- - - -trick question- - - -how do you explain the concept of "clockwise" to a kid whose only experience with telling time is by looking at a digital readout on his/her smart phone? Jerry
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Now- - - -trick question- - - -how do you explain the concept of "clockwise" to a kid whose only experience with telling time is by looking at a digital readout on his/her smart phone? Jerry Hmmmmmm...... | | | | | Joined: Apr 2017 Posts: 480 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 480 | forget about clockwise, try to explain quarter to or quarter after! When I was teaching Chemistry I got tired of kids always watching the clock to see if the class was almost over. So I put up a clock that ran backwards! Eventually they figured out how to tell time with it, but one kid told me "now I can't read the clock at home".
Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road. Tim
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | That's known as a "bartender's clock". It's designed to hang behind a bar and be read in the mirror. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It is also called a Grace Hopper clock (but, she was not the first). | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Now- - - -trick question- - - -how do you explain the concept of "clockwise" to a kid whose only experience with telling time is by looking at a digital readout on his/her smart phone? Jerry I spend some of my time at work teaching the younger generation how to locate targets at night with night vision equipment from the bed of a pickup truck. Since the shooter cannot see the targets, the spotter must relay the relative position of the targets. 12 o'clock, 3 o'clock, etc. Problem is, they had no concept of analog clock faces! I was flabbergasted! Then I had to take the time to explain to them what flabbergasted meant. Carl BTW, I am on topic. There is the phrase "pickup truck" in my post.
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Dad learned aerial gunnery in 1944 from the back of a moving pickup truck- - - - -shooting skeet targets with a 12 gauge pump shotgun mounted on an M-2 machine gun carriage! Jerry
