1 members (Gray_Ghost), 65 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#1275548 08/08/2018 8:14 PM
My 327 busted it's block so looking for replacements. It's in a 59 3100 short bed deluxe fleet side. The 327 is from 1969 that was installed i'm told in the 70s. It ran great till now. It uses the old style front rod mounts, the ones a 265 would use. I'd like to stick with this setup. Other than the 69 327 what other SBC's will mount in this manner and fit the bell housing and 3 speed which i believe is the truck's original? I can get a rebuilt 327 from '69 but curious about options. Just starting the hunt.
thanks
greg
1959 Fleetside Apache Deluxe Shortbed
GreginPa #1275556 08/08/2018 10:09 PM
Any small block V8 with the holes in the front of the block drilled and tapped for the mount brackets will bolt in. If you use a 350 from the 1980's or newer you'll probably have to install a small diameter harmonic balancer- - - -the 8 inch balancer will probably interfere with the front mount brackets. I've seen a few installations with those brackets notched out for a big balancer, but it looks kind of Mickey Mouse, and the smaller balancer works OK on the 350.
GreginPa #1275560 08/08/2018 10:32 PM
Thanks Jerry, Is there any problems with the flywheel, bellhousing, etc with the later engines?
GreginPa #1275563 08/08/2018 11:41 PM
Not until you get into the engines with the full-circle rear oil seal and four bolts down the center of the valve covers- - - - -don't remember when that change happened, but I think it was early 1990's maybe?
Thanks again Jerry. I basically have lots to choose from then.
Virtually all small block V8's from 1958 or so when they started using side engine mounts on the passenger cars to the early 90's are pretty much a bolt-in swap regardless of displacement. The small block 400's use externally-balanced crankshafts that require special harmonic balancers and flywheels, but they still have the capability of fitting the same mounts.
1 piece rear main seal started in 86 and center bole valve covers in 87
50 chevy 3100
