| | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I have 2 Rochester bs on my 1954 235. If it was yours would you replace them with Rochester's or switch to other brands and what would that brand be? One of the carbs is original to the truck and the other was an aftermarket purchase.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | 235 carbs are WAAAAAYYYYYY too big for a dual carb setup to handle if you're feeding that same engine with two of them. There's no way to turn that 235 into a 470 cubic inch engine, no matter how much boring and stroking you do. 216 carbs would be better, but not by much- - - -they're still capable of feeding a 432 cubic inch engine. Dual Rochesters of any size are double trouble. Get a couple of Carter YF's, the 951S series. They're made for a 140 cubic inch Jeep F-head engine. You'll only be a little over-carbureted, like for a 280 cube engine! Jerry
| | | | | Joined: Mar 2014 Posts: 4,511 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,511 | If it were me, I'd get a stock intake manifold and replace with one model BC properly rebuilt and jetted correctly. Make certain it is rebuilt with ethanol resistant parts and make certain the airhorn either wasn't warped or has been fixed correctly. Please note: I'm not as negative about the Rochesters as some, and while I could be wrong I believe I can come up with ways to solve some of their problems and basically I don't believe they are bad carburetors. I say BC because long ago I decided a working auto choke was much better at its job than I'd be.
Or get a Carter if you prefer, but if you drive your truck infrequently enough that your carb becomes dry I believe there is a neoprene part in there you'll become handy at replacing every year or two and if it gets dry enough it is possible you might have to replace more often than that. But hey...once you've done that a couple of times it will give you a reason to never let that carburetor become dry. If you want an example of what neoprene does when it dries out, ask any plumber or tilesetter...even an apprentice. It is one of the first things he/she learned about toilets and the reason any tilesetter worth hiring figures out what toilet bowl seals will be needed at the end of the job.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | The only problem with the advice on the carbs is, that I have been driving with them for over 12 years with no issues. What I am trying to do is eliminate what could have caused the drastic gas mileage drop. Jerry thinks it is the carbs and I respect his opinion but the issue raised it's ugly head after I came back from HQ a year ago April and I averaged 20 mpg then, when I went to KC in Sept. it had dropped to 15mpg. The carbs were not touched at that time. I did have electrical problems. First, it stopped and would not start, I fiddled with it and finally got it started and drove 5 miles home, the next morning it would not start, no power to the coil, so the mechanic thought it was the HEI coil so he replaced the internal parts and still no start. I thought maybe it was the ignition switch so to see what type it was, I reached behind the dash to check the connector then I tried to start it and it did, it was just a loose pin type connector. I tried to find someone to check the dwell but nowadays shops don't bother with that, everything is electronic. I live in a small town. I did think of 2 places that may be able to check it. The search goes on.
| | | | | Joined: Apr 2008 Posts: 16 New Guy | | New Guy Joined: Apr 2008 Posts: 16 | There is no point in checking the dwell in an HEI system because the ignition module keeps adjusting it with RPM. The HEI will either work or it won't and it seems to be working.
If your fuel economy dropped but the fuel and ignition systems seem to be working fine, I would check other things like timing advance. Have you checked your vacuum advance canister for leaks? | | | | | Joined: Nov 2002 Posts: 2,777 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,777 | I have 2 Rochester bs on my 1954 235. If it was yours would you replace them with Rochester's or switch to other brands and what would that brand be? One of the carbs is original to the truck and the other was an aftermarket purchase. If it was mine, I would replace the intake manifold with a three-carb manifold (for either side-draft or down-draft carbs). If it were side-draft, I would use three Carter type YH carbs number 2618s from a Dearborn marine engine (most common of the YH series) and recalibrate for the Chevy. If it were down-draft, I would use three Carter type W-1 carbs from a 1939 Chevrolet, part number 420s. In the meantime, I will remain happy with my off-topic shop truck (brand name same as an old country singer from Tennessee) with a 390 and two 625 CFM genuine Carter AFB's running solid linkage that gets 22 MPG at 70 MPH (it doesn't do this well in town with my foot in the rear carburetor  ). And they have been on the truck for 18 years, without being touched! Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Ditto on the three carbs- - - -but put a piece of solid aluminum sheet metal under the two outer ones.
| | | | | Joined: Nov 2002 Posts: 2,777 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,777 | Jerry - they need to run straight linkage, NOT progressive.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | If they block off the two outer carbs and make them eye candy like they should be, linkage style is irrelevant. Jerry
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | fraso, what you advised follows my suspicions. The distributor was the thing messed with the most just before the mileage drop. It also reinforces what I experienced last Saturday coming back from a 300-mile trip. The truck seemed to top out on the slightest rise. On my trips to KC, 8, there are some hills that are long and even with cruise set it does not slow down and has extra if it needs help. Will have it checked and maybe replaced. I went online and watched checking and adjusting.
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Didn't you find a problem with the speedo being off in another related thread????
One of the worst things to do is fix some thing that ain't broke.....
| | | | | Joined: Dec 2008 Posts: 1,923 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,923 | Pontiac Sprint OHC L6: 230", 750 CFM QuadraJet = 3.26 CFM per cubic inch. | | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | Did you check your odometer accuracy as per your thread in the "Spoon?"
1951 3100
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Yes. I am installing a new vacuum advance later this week and having everything check.
| | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | You're losing 5-8 degrees or more of timing advance at light throttle cruise speed. That will definitely have an adverse impact on gas mileage. It's like the ignition is set for a hard uphill pull all the time. Jerry
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Dave, I should have left things alone but of course, I did not. I assumed the odometer was off and I attempted to reprogram it. In this convoluted process, you have to push and hold a button for so many seconds to calibrate the rear end ratio then by driving a measured mile and I assumed that mile roads here in Indiana are a mile, not. So then I got out the trusty Gps on my phone and measured a mile but just as you are ready to set a car comes along and you have to move and start all over. This a backcountry rural road in the middle of the day. Then I had the electrical problem. I still think it is the problem and I picked up a new vacuum advance today and will have the timing set per specs. I know HRL only got 5 mpg on his trip in the fire engine/truck but when you have been getting 20 mpg on a long trip and it drops to 15 mpg something is off. Also, the in-town mpg is down from 14-15 and now 10-12
