| | | Forums66 Topics128,158 Posts1,057,023 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2018 Posts: 46 | From what I understand, 1950 was the last year for the old style drum brakes, I think they are called Huck brakes, and I am guessing they are not self energizing.
Is that all correct?
Secondly is it possible to fit backing plates and brakes from a later year truck and retain the original 6 lug wheels, and original spindles / axels?
1950 GMC 1/2 Ton Long Box 228-Zenith carb- SM420-bendix brakes
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Yes , I fitted Bendix from a '54 truck , to my '40 . There was some minor adjustments to make , one I can remember was the 2 bottom bolts on the steering arm were larger diameter , maybe from 7/16" to 1/2" . I'm sure someone else will fill in the gaps , I did this 20yrs ago and no longer remember it all . | | | | | Joined: Aug 2018 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2018 Posts: 46 | Will this work for the rear brakes as well?
| | | | | Joined: Feb 2004 Posts: 29,870 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,870 | To upgrade to Bendix brakes you'll need to swap the entire brake assembly- - - -backing plates, shoes, drums, probably front hubs, etc. If you can figure out a way to make the backing plates fit the rear axle housing and the axle flange is the right diameter to center the drums, I don't see a reason the whole system couldn't be adapted. Be sure to factor in any differences in the bore and stroke of the master cylinders- - - -that might need to be changed as well. Jerry
