0 members (),
311
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | On a '49 3100 what's the easiest way to change the filler grommet? If I loosen the vent and fill hoses inside the cab and slide the metal filler pipe out a little can I remove the old and squeeze in the new from the outside?
Ed
| | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | Ed, I replaced the one on my 1954 3600 and it was necessary to completely remove the filler pipe. You should be able to loosen the fill hose and vent hose clamps, wiggle the hoses down as far as they will go on the tank, pull the filler neck up ,and angle the bottom out towards the dash and then pull it down and out. Replace the filler grommet and reverse the process. It looks like it gonna be way more difficult than it actually is. I do not think it can be done otherwise. Hope this helps.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Ronnie,. Thanks for the help. Always good to hear from someone who's been there. Ed
Ed
| | | | | Joined: May 2018 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2018 Posts: 51 | Like said above and Lots of soapy water...
J. F.
J. F.
