2 members (3100RustyParts, lumbersawyer), 114 guests, and 1 robot.
Topics128,260
Posts1,058,318
Members48,485
Hey all, I have a kwik wire wiring harness. When wiring up the turn signal switch, the Yellow wire goes to the left front headlight, green to the right front headlight, brown
to the right rear tail light,orange to the left rear tail light, red to the stop light,black to the turn signal flasher.
My question is the remaining wire on the turn signal switch is the blue wire, what wire on the kwik wire harness does the blue wire connect to?
I'm getting so close to starting up the truck for the second time.
Thanks again guy's for your input.
Elmo
"P" post on the flasher
for the pilot light
DADS50, What is a pilot light? And what does it do?
The light on the switch that blinks
Sir Searchalot
Sir Searchalot
The flasher has either two prongs or three prongs. "X" for power-in and "L" for lights and "P" for pilot, as Dads50 says. The L and P are the same. They give off a blinking voltage to whatever bulb they are connected to. If you have a three prong, attach blue to P. If you have only two prongs attach blue to "L". If you have a dash mounted indicator light, you would wire the bulb to L or P.
Now-a-days we call the pilot an "indicator" that blinks along with the truck lights to let us know it's blinking so we shut it off after the turn. These column mounted units don't have self cancelling. They have yourself cancelling. I guess some have a cancelling bracket.
If your T/S unit does not have an indicator, attach blue to a seat belt chime.....or unconnected.
Former BMW Rider
Former BMW Rider
Here's a copy of the wiring diagram I used. Maybe it will help you out........
Good luck!
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
Thank you everyone for all your information. I got that wired up
Elmo!!
