5 members (Wally / Montana, 3B, GMCJammer51, Shade Baby, greenie-reddy), 71 guests, and 1 robot.
Topics128,154
Posts1,056,834
Members48,456
Replacing the seals on the transmission end of the drive line. Does the end assembly slide forward and off ? I looked in the 54 Truck Manual but I could not find the procedure.
My old seal is made of rubber, new ones are cork. Will the old cork style ok to use or should I get the rubber type ?
54 1/2 ton with Hydra-Matic transmission
Thanks. Michael...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
Michael,
I might not understand your questions.
In order to install new u-joint bell/ball seals, you have to disconnect the u-joint assembly and slide the yokes apart.
Here is the parts kit (you should use all new seals/gaskets):
https://www.classicparts.com/1935-54-U-Joint-Ball-Gasket-Seals/productinfo/92-111/
Here is the gasket adjustment procedure (UNIVERSAL BALL JOINT ADJUSTMENT) in the Shop Manual.
I think my seals have been cork.
Tim, to replace the seals I need to Remove the universal joint ball from the torque tube.
In the UNIVERSAL BALL JOINT ADJUSTMENT in the Shop Manual, " Remove the universal joint ball from the torque tube ". It does not say how. Does it just slide forward and off ?
The yoke came out ok and is in good shape.
Thanks DADS50, I got it of. Was stuck tight on the torque tube.
thumbs_up
