| | | Forums66 Topics128,148 Posts1,056,810 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Replacing the seals on the transmission end of the drive line. Does the end assembly slide forward and off ? I looked in the 54 Truck Manual but I could not find the procedure. My old seal is made of rubber, new ones are cork. Will the old cork style ok to use or should I get the rubber type ? 54 1/2 ton with Hydra-Matic transmission Thanks. Michael...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Tim, to replace the seals I need to Remove the universal joint ball from the torque tube. In the UNIVERSAL BALL JOINT ADJUSTMENT in the Shop Manual, " Remove the universal joint ball from the torque tube ". It does not say how. Does it just slide forward and off ? The yoke came out ok and is in good shape.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Thanks DADS50, I got it of. Was stuck tight on the torque tube.
