7 members (Peggy M, mick53, Steelonsteel, Otto Skorzeny, Robert Crandall, Charles in CA, JW51),
130
Mod | | | Forums66 Topics128,109 Posts1,056,267 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,804 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,804 | Has anyone tried one of the 'dent lifter" kits on the market, the ones that involve using a hot glue gun to stick a stud onto a painted surface and lift a ding without any surface prep and repainting? The kits look like sucker bait, and I believe I could home-brew something very similar and accomplish the same end result if the procedure actually works. Thanks in advance for any comments! Jerry
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Personal experience, it can work. Certain types of paint are subject to lifting thus a repaint is necessary.ðŸ›
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Depending on the dent....I have used the hand held gizmo's glass installers use. I've popped many dents out with one over the years. (yeah, some I couldn't get out)
| | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | it will work on a "gentle" dent with no metal stretching or creasing - it doesn't work miracles. its worth a try | | | | | Joined: Sep 2013 Posts: 1,363 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,363 | Not answering the subject question and of course not knowing the dent's location, this may be useless info, but I've had good luck popping door and some fender dents using inflatable items. Soccer balls or kids basket balls. If there's sufficient structure behind the dent to back the inflatable it can work great. Several kits on the market as well with pneumatic bladders.
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Feb 2004 Posts: 29,804 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,804 | When I ran a high school body shop we used that procedure pretty effectively. Once the ball is inflated a little, tapping around the perimeter of the dent with a flat hammer helps eliminate creases. Some of the videos I've watched concerning the "paintless" process employ the same technique, using a rawhide mallet or a rubber hammer. A text on metal bumping I taught from frequently was written in the mid-1930's, and included lots of techniques for metal finishing that minimized the need to use lead for final finishing. Bondo was still a couple of decades in the future when that book was written. Jerry
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | I watched a traveling paintless dent remover guy push out many hail storm dents on a truck roof while the rest of us were dove hunting. He had long handled tools with bends near the end and were tipped with what looked like a ball bearing. Super polished. After he had most of the dent pushed out, he said, "Hold my beer, you're going to like this part." He then pulled out a body hammer with a mirror-finish face and proceeded to lightly hammer on the paint while continuing to push out with tool. It did not harm the paint whatsoever. When he was done, you could not see any dents nor paint damage.
| | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | PDR works great on the new stuff not to surer on old iron. Repainted vehicles can be tricky as the paint may crack.
| | | | | Joined: Feb 2004 Posts: 29,804 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,804 | OK- - - - -got the essential bits and pieces to make up my own PDR kit, for a fraction of what the ones on Ebay are selling for. Hot glue, angle iron, fender washers, and 1/4-20 flat head screws make up the basic components. I'll glue a screw and washer to the body panel, then use the angle iron with a series of holes drilled in it as a lever to lift the dent. A small square of plywood under the end of the angle iron will spread out the load at the fulcrum end of the lever. The hot melt glue gets released with alcohol, hopefully with no damage to the paint. If things work as planned, I'll write up a report on how it goes. The vehicles I'm experimenting on don't have enough value to worry about making a few mistakes- - - -any improvement at all will be welcome. Jerry
| | | | | Joined: Sep 2013 Posts: 1,363 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,363 | Sound plan, looking forward to the results. My wife's new truck (back in '15) was foolishly parked under a boisD'arc tree in July when it was new. Luckily the two boisD'arc apples hit the roof. I've tried to pop the dents out with a can of air with Freon (or propane) as the propellant/cooling agent in direct, hot sunlight without much luck. Your system might just be the ticket. The good news is 3/4 ton, 4X4s these days are so tall that the only ones that see the dent are class 8 truckers and they've never criticized.
RonR
| | | | | Joined: Mar 2014 Posts: 4,499 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,499 | I watched a fellow around 1967 remove several hail dents with dry ice in a relatively new Nova...body shop at a dealership. He parked the car in full midday sun for a couple of hours then broke his dry ice into pieces about the size of grapes. He then put a piece of dry ice into each dent and within a few seconds most of them popped out. He said sometimes it took a couple of tries, but added he could get all but the really large ones out that way.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Apr 2016 Posts: 1,047 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,047 | You can buy dry ice in pellet form. I'm building a plant now.
| | | | | Joined: Aug 2001 Posts: 3,599 Moderator | | Moderator Joined: Aug 2001 Posts: 3,599 | Where can you buy dry ice? My parents would get a block of it when we went on vacation and took frozen meat in a separate cooler. That Ice in a good cooler would last about a week.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 |
| | | | | Joined: Mar 2014 Posts: 4,499 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,499 | Don, if you have a CO2 fire extinguisher and a pillow case or athletic sock you can make it yourself in a blink. Tape the pillow case over the extinguisher's nozzle, open the extinguisher for a few seconds and you'll have dry ice in the pillow case or sock when you remove it. The pillow case/sock is just there to let the gas escape and leave the solid behind. But it will be much cheaper to purchase it already made.
Supermarkets sell it here out of what looks like a chest type freezer serviced by some dealer downtown or in Ft. Worth. Last I looked you could get a block or you could buy a sack of pieces at $1.50 per pound. El Rancho, Tom Thumb, Kroger, Fiesta Mart, Wal-Mart, Costco, etc. I don't believe as much is bought around here as in more remote places, however. When I grew up it was very common to get it at the locker plant or the ice house and people living out on ranches would get some every week. Especially during hunting season. The locker plant supplied the schools with what they needed (field trips, science classes, halloween carnival, things like that). They had metal coolers and they were always using it for something. I'm certain the ice houses here (and probably where you live) sell it in bulk.
| | | | | Joined: Aug 2001 Posts: 3,599 Moderator | | Moderator Joined: Aug 2001 Posts: 3,599 | Thanks Jon! I'll ask the wife to check into the walmart supply. She has worked there for over 35 years and can get a inside scoop.
Thanks Don
PS: don't tell anyone, it's for my old F-250.
1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Mar 2014 Posts: 4,499 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,499 | If they don't have it for sale, have her ask the produce manager at Wal-Mart or any grocery store. Almost all of them keep dry ice for their own use and if you aren't abusive, they're usually happy to give you some.
| | | | | Joined: Apr 2016 Posts: 1,047 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,047 | If you google Continental Carbonic They should be able to tell you who they deliver to in your area. If you keep the air off of it it will last much longer. Do not put it in an airtight container it could explode. Also do not touch it. It will burn you. Temp. -110 F
| | | | | Joined: Oct 2016 Posts: 83 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 83 | PDR works great on the new stuff not to surer on old iron. Repainted vehicles can be tricky as the paint may crack. This is my experience too. I bought one of those kits that use the plastic pull rods (that break after a few uses) and was able to pull out the small 1/2" door dings fairly well, but it was all done on newer vehicles with thinner gauge metal. I seriously doubt the glue-pull method would work on the old iron. It seems like most of the sheet metal could be accesses from behind on the old vehicles so the rods could used instead. Far better results from behind. | | | | | Joined: Feb 2004 Posts: 29,804 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,804 | The old-school body repair I taught occasionally during my career in public education made use of "pick tools"- - - -curved steel pry bars used to raise dents in areas not directly accessible to hammer and dolly work. A combination of the glue-on pull rods and some gentle massaging from the back side seems like the best approach to raising dents without disturbing the painted surface, as long as there's no sharp creases and/or paint scratches involved. Like with any other mechanical or sheet metal procedure, I'm sure there's no substitute for plenty of hands-on experience. Jerry
