| | | Forums66 Topics128,136 Posts1,056,431 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | A long-time tech tip has been to back a hole with copper and fill it with MIG wire to close it up. Now, I've done this, but always had to grind it smooth. The back is pretty good- has anybody put the copper on the "front" of the hole and welded it up from the back to reduce grinding? I have a couple of tailgate holes to fix.
Riddle me this- if you drill a small divot in the copper backer the same size as the hole, and you weld it from the back, do you get something proud of the hole that is easier to grind?
Maybe I just need to try it this weekend, but I'm out of shield gas.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I was just wishing I could weld my doors from the backside-my doors are off of a big grainbed bolt w/huge mirrors-rust free but ten 3/8" holes in each door. I dunno about the drilling the divot, seems the copper does the trick leaving just a small bump needing only minor grinding. | | | | | Joined: Jan 2002 Posts: 2,841 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,841 | I've always wondered about the copper trick. Are you saying that you hold for instance a sheet of copper up against the back side covering the hole and then just fill the hole with mig? I assume that the mig wire will not adhere to the copper? Does the copper need to be of a certain thickness?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Craig, I'm just using 1/2" or 3/4" copper water pipe smashed flat. Your MIG tips are copper or copper plated, the weld won't stick to it. | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | Originally posted by 64fleetside: Craig, I'm just using 1/2" or 3/4" copper water pipe smashed flat. Your MIG tips are copper or copper plated, the weld won't stick to it. the nice thing about the pipe is you can cut it to the correct length to reach the hole.shimm stock works great with a couple strong magnets from radio shack. nice thing about shimm stock it's light.  | | | | | Joined: May 2007 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 36 | I found using a tig welder and brass rod works very well.It fills the hole almost flush and almost no grinding. | | |
