3 members (Phak1, Oswald, 1 invisible),
154
Mod | | | Forums66 Topics128,288 Posts1,058,566 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | So Old Blue, my 3600 Stovebolt, came complete with four pretty badly worn tires on the original split rims and all four original hub caps. Pretty common with most of these original medium duty Stovebolts Since I’m a 95% purist, I spent a couple days breaking down those darn split rims took them to the sand blaster, painted them with some good PPG enamel and bought four new bias ply’s, tubes and flaps and let the tire dealer mount and balance them for me. The were used to the split rims because they did a lot of farm and truck business. Well…..after that first year of tooth jarring startups because of the bias ply’s, I started my search for some new rubber. New rubber meant the split rims had to go, so….I found some ’80 GM 16.5” rims and mounted up some new Cooper radial’s. What a world of difference in the ride. Problem now was I couldn’t use my original hubcaps with these modern GM rims. Easy solution, I got clips from one of the vendors and along with some round stock standoff’s I turned in the lathe and some 10-32 screws, I mounted the clips. They worked great for almost 10 years, never lost a hub cap. But…..I still felt the ride could be a little better and tires for the 16.5” rims were by now getting pretty hard to find and were quite limited, besides, if I had a blowout it would be a real pain in the ars finding a new 16.5” tire. A search of the junk yards turned up four nice ‘96 Ford F-250 16” rims, which after blasting and painting with Valspar (never do that again, took forever to cure), I went all in and put a good set of Michelin radials on the old gal. Now she finally was riding nearly as nice as my new Silverado. A new problem though…those original hub caps again. This time it twern’t gonna be as easy. The land between the lug holes was tapered 14° on these Ford rims, so I couldn’t just use a simple stand off like on the Chevy rims. A couple of evenings at the drawing board and I came up with a 14° wedged standoff. Got one mounted up today and I’ll finish them off tomorrow when my special screws get here. So here’s the original ¾ ton hub caps mounted on late model tubeless rims. Scroll thru a few pix of the wedges if you’re interested in using the idea for your ride: http://www.pbase.com/dennygraham/image/167852800/large http://www.pbase.com/dennygraham/image/167852801/large http://www.pbase.com/dennygraham/image/167852802/large Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I like yours much better than mine. Although they have been trouble free for years having a mechanical connection is to my liking. Mine are rare earth magnets epoxied to the wheel covers (hub caps) and iron, not steel discs on the front hub caps and rear axle centers. Thought I might need alignment pins but this turned not needed. Getting the spacing right was a pain and each cap is position specific. One has to pry HARD to get them off. Yours are beautiful.
Evan
| | | | | Joined: Jul 2004 Posts: 2,999 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,999 | You're only a 95% purist now, Denny? When did that change? You used to be 100%! You must be slowing down in your old age! | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Apr 2008 Posts: 64 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 64 | Thank you Mr Graham. I am slowing working toward exactly what you did. I was trying to figure out how to get around that taper. Your pictures help greatly.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Nice solution.
Another option is make new spring steel clips with the correct shape for the unique application. Start with annealed spring sheet stock and have them heat treated if you can't handle that part in house. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | If anyone uses aftermarket wheels (Wheelsmith, Wheel Vintiques, etc.), Wheelsmith will modify your caps to fit any style of wheels they sell. I used Wheel Vintiques Artillery wheels, which I knew my repop GMC caps wouldn't fit. Wheelsmith modified my repop GMC caps and they fit very snug, I'm very happy with them.
Just another option. Cool solution, Denny. | | | | | Joined: Nov 2004 Posts: 2,432 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,432 | Nice job Denny.  John
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Real nice, as usual, Denny | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Denny, what is that piece I see between the wedge and the wheel? Wood? Rubber? Gasket? Optical conclusion?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | What cha don't see ya don't need to know about it Rich. So I can hide 5% of my restored Stovebolt and no one is the wiser. Phill, just get some 5/8 square aluminum bar from McMaster and cut your wedges 1 3/4" long and at 14°. That should put them pretty close, although you may need to shim them or touch them on a belt sander. You can stuff a camera inside from the back and snap a picture to see if the locking lip is engaging fully in the clip. If you have chevy rims.....then all you need to do is make a standoff from some alum round stock with a 3/16" hole drilled thur it. Tried that 10 years ago Grigg. Got some spring steel from McMaster and made a whole batch of taller clips for the Chevy rims and tried heat treating them myself. Lacking a good oven some got to hard and I couldn't draw them back to a temper some just didn't get hard enough. After a lot of frustration I settled on the factory made clips from the vendors and a few simple standoffs. They've held great all these years and the caps snapped on and off just like on the original rims. Leather shims Bart. The original 3600 caps have a little over 9/16 locking lip and the reproduction caps are a little under 1/2" so you have to shim them different. The leather also conforms to the slight radius on the boss and make the wedge sit good and solid. I use 10-32 x 1 T25 Torx head screws with nylock nuts on the back side and they sit rock solid. dg
| | | | | Joined: Apr 2008 Posts: 64 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 64 | Denny, Thanks for the tip on the square stock. I have the same F250 wheels so I will follow your lead on this to make my Chevy caps work. Thank you for all your great tips and innovation. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | HOLD ON!!!! This is like the Never Ending Story......gotta give a warning to any of you guys driving a big Bolt and trying to fit original hub caps to modern wheels. I've got wheel spacers on the front of my 3600 and in between the lug studs there is a counter bore where the spacer bolts to the original lugs. Because of this, there isn't a clearance problem for the hub cap clip nuts on the back side of the wheel rim. But....the back wheels bolt flat to the drum and a nut or portion of the thread that sticks thru the nut will keep the wheel from seating. So......It's necessary to run the screws in from the back side and use the nuts outside. Ask me how I found this out???? As I wrestle with the bunged up 10-32 threads on the back side of the RR wheel.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Can you drill and tap the wheel for 10-32 and not use any nuts, and nothing poking out the back?
I removed some clips from original wheels recently to have everything powder coated nicely, plan to reattach with 10-32 stainless button head or round head screws. In my case also need to install helicoils because rivet holes were a little large to just tap. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That was my first thought Grigg. Don't know how thick your rims are but the Ford 3/4 ton rims are only about .100". Hard to tell exactly because it varies depending on where you are measuring since they have a lot of contour and stretched areas. That would only give me a little over 3 threads in the best case scenario. I used Torx pan head screws and that leaves plenty of room on the back side of the rim for a flush mount. Remember now....we're talking about the Ford 3/4 ton rims from the 90's. I think all the rims I found have a stamped mfg. date of '96. Denny G Sandwich, IL
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Got it, I was working with old GM rims, they're quite thick where the clips were riveted in, plenty of meat for a 10-32 screw.
I bet you could get by with two screws holding on your adapter block if there's room, 0.100" is likely enough meat in that case. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Much easier for me, to just run a machine screw and safety nut it. But.....there's always a dozen ways to approach a problem, to each his own. Denny G Sandwich, IL
