| | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | 1950 12v suburban stock guages.....
When I installed my new gas tank last year, I put a new gas tank sander unit in it. The sender unit has a wire grounded to the unit, also a positive wire from a stud on the sender. I purchased a gas guage voltage reducer also.
I assume the ground wire grounds to frame but I am lost as to where the positive wire / reducer should go???
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The voltage reducer goes on the back of the gauge on the E post then your power wired connects to the voltage reducer.
The sender wire goes to the gauge F post | | |
