0 members (),
146
Mod | | | Forums66 Topics128,162 Posts1,056,939 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | I had my 1953 GMC grill chromed and they did not put rivets in all the holes. The question I have is whether I should put stainless steel rivets in the missing holes or should I replace the existing rivets with stainless steel nuts and bolts? | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I don't know that you can even get stainless steel rivets, stainless isn't very malleable (unless you are talking about the aluminum pop rivets that look like stainless).
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Little SS nuts and bolts for me. | | | | | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | I was able to special order stainless steel rivets. Right now I have the option of using the stainless steel rivets or stainless steel nuts and bolts. | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Be careful if you are buying SS pop type rivets they will not work in a standard pop rivet gun as the rivet is very hard and more than a hand grip is needed...make sure you have the correct type of gun as the jaws for SS rivets are also different. T/C Steve | | | | | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | I did buy SS pop rivets. I didn't know they were different size and would not work in a normal hand rivet tool.
I gues that puts me back to using the SS nuts and bolts.
Thanks for the info. | | |
