| | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | Well, I seem to be down to the carb issues. After checking the torque on the manifold bolts as best I could - inner bolts are hard to access, I cranked up the engine and proceeded to dribble fuel over the intake manifold to cylinder head junctions (not to be attempted by those with a fear of self immolation - but it works). The front and rear ports have a significant leak. Is this a common problem? What do I do - add more gaskets, resurface my manifold?
BobS46
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1. more gaskets, or a thicker gasket might solve the leak problem
2. have the mating surface on the manifolds planed/surfaced at a machine shop.
| | | | | Joined: Mar 2014 Posts: 4,501 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,501 | I've found things work better for me if I leave the two manifolds loosely attached (they'll wobble around a little), then attach both intake and exhaust manifolds to the head, get them tight against the head and once that is done tighten the intake and exhaust manifolds together where they meet. Hope that makes sense.
Good luck! Jon
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | Thanks all. I will try building up the gaskets before pulling the manifolds. Jon's suggestion also sounds solid.
BobS46
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Try using a Remflex gasket. It is a one piece gasket that takes care of both the intake and exhaust manifolds. Made of graphite it is supposed to span gaps up to 1/8 inch thick. Kind of pricey at around $35 but cheaper than machining the manifolds. Take care on installation and do not bend or it will break and be ruined. With no carbon compounds in the material it is supposed to last much longer than standard material.
Kent P.S.You want stock number 2027. You are supposed to torque to 20 ft.lbs, with no re-torquing required.
Last edited by Lightholder's Dad; 07/22/2018 11:24 PM. Reason: Additional information
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Sometime the port rings will hold you out, so check that they are inserted correctly and not to thick. Ive had to dress mine down after I had the manifold machined.
I also found to helpful to leave the heat box loose and tighten it in sequence.
Manifold torque 20 ft/lbs on center clamps 30 ft/lbs on outer | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | In your situation, unless there is a leak between intake and exhausts manifolds, do not disconnect them.
Otherwise, try the Remflex at $49 +shipping | | | | | Joined: Mar 2010 Posts: 10,282 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,282 | Find a wrench which better fits in the tight spots on the middle bolts, or grind or heat and bend the wrench that you already have. Loosen all of the bolts, then tighten each one to less than final torque specification (10 ft-lbs). Proceed to tightening them to final specifications (20 ft lbs center bolts, 30 ft-lbs outer bolts).
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "inner bolts are hard to access" Get a thinner/better box end wrench, or use an open end wrench. You should not have to torque the nut more than 20-40psi. inner bolt are torqued tighter than outer bolts (if that really matters) See page 16-19 - that spec should be OK for a 235.Shade-tree/farmer specs: Tighten lightly/snugly, all nuts Then, retighten each nut a little more to an even/equal resistance for all Then, retighten each nut a little more | | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | I was planning to use a crowfoot wrench for the bolts. It might even help me to get my torque wrench on the bolt.
The specs are interesting - I have a copy of something from the internet that shows the inner and out bolts are just the opposite values - but it was not copied from a manual. I believe that I will go with yours.
BobS46
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | " I have a copy of something from the internet that shows the inner and out bolts are just the opposite values "
dyscalculia? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | My guess is that the two outer bolts are longer and the clamp is about 1 1/2 futher away from the head might be the reason for the original torque spec? | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | The face could be warped, its not all that common but is certainly a possibility. A reasonably well equipped machine shop should be able to face the manifold assembly. Don't take it apart, have the manifolds faced as a unit if you decide to do this. Otherwise, get a Rimflex gasket as above recommended. The Rimflex works really well. Tight spot on the inner bolts, yes. Some wrenches just wont fit. I have an extra long Mac wrench, and a smaller wrench that I modified, to fit and snug down the clamp bolts.
Mike
| | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | I decided to go with the Remflex gasket. It arrived today, and guess what - the package had been bent! Now, the gasket is not "broken", which means to me to be in 2 or more pieces. But there is a slight crease in the face of the gasket between the bolt hole and the center intake hole. There is less of a crease across the center intake hole. looking at the edge of the gasket, I see no visible damage. Do you think it is worth taking a chance on this gasket?
Bob
BobS46
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Remflex look great, however, they are not made for many engines.
Ed
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Contact the company and ask if the gasket is ok to use.ðŸ›
| | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | To follow up, the Remflex solved all problems with the leaks. The crowfoot and a "click" torque wrench allowed access to all but the bolt right behind the carb, which had to be guessed at by hand.
BobS46
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I use the “flat method” on bolts I cannot get a torque wrench on
Basially you mark the bolt head on a bolt you can get a torque wrech on after tightening them hand tight
Then notice how far the bolt head moved after final torque
Thghten the one you cannot get the torque wrench on the same diatance.
Mike
