6 members (Bill Hanlon, fonz8261, Shaffer's1950, tclederman, Hotrod Lincoln, Charles in CA), 70 guests, and 3 robots.
Topics128,087
Posts1,056,376
Members48,442
Hello, I have a 1964 Aluminum 2 spd Powerglide being installed in my 1964 1/2 ton C10. I am using the original automatic column shifter. I received (from 4-5-6) the pivot link that attaches to the frame, but the center link is really worn. I am not sure what the original looked like and I was wondering if anyone knows if the areas indicated in these photos need to be completely filled in with weld? Thanks, Janine
Can’t view the photos. Wants me to join Facebook. No way!😠
Martin, Sorry about that. I understand where you're coming from since I have a hate/like relationship with FB. I Figured out how to just add the pics. Janine
Hey, you’re a better person than me. Being a Moderator you would think I can do it all, but I can’t figure out how to post photos. Your pieces would be an easy fix for a good welder. 🛠
