4 members (klhansen, Rich'sToys, walter74, 1 invisible), 133 guests, and 1 robot.
Topics128,062
Posts1,055,854
Members48,428
porky here.
so i'm mounting my standard heater and today i struggled with the heater bracket near the vent hoses. Does the bracket mount to the bottom of the dash or does the bracket rest/sit inside the dash? everything so easy causes me headaches....i've attached a picture of what i'm referring too....
thx porky...
1959 Chevy Fleetside 3100 Series BBW
Without going out to the tractor shed for a look, I think it mounts to the bottom with a spring nut clipped to the dash.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
thanks Mike.... Not to familiar with a spring nut, but I'll look online to see as in theory i understand the concept due to the cab vibration etc. i have the shop/production manual but can't find a pic or the section that specifically relates to the heater and how it mounts..
porky...
heater info is only found in accessory manuals .... I had that heater in my 58 and found it fit well with the bracket on top the dash lip
This was the nut I was thinking about...
https://www.mcmaster.com/#clip-on-nuts/=1drv7c5 (top right)
If Bill had it on top, go with that. I went out to the garage just now to look at two heaters I have (1956 and a 1957) and neither of them have the bracket, so the 58/59 heaters must be different than the 55-57. So now I'm second guessing myself...happens with age!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
