8 members (Wally / Montana, Steelonsteel, Tronman, 1955 1 Series, Bill Hanlon, Hotrod Lincoln, LAROKE, 1 invisible),
137
Mod | | | Forums66 Topics128,201 Posts1,057,279 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I have a 2001 Suburban, original owner. The horns are shot. I like the sound of the earlier 12 volt horns. I would think that a 50's 12 volt should work being 12 volt is 12volt. Is my assumption correct.
I do not want to spend money only to find out that they will not work. Jeffrey | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Depending on what 12v 55/56 or later horn you plan to use, be sure to get the relay-fixture, if there was one. | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | I would think 12 volts is 12 volts.
| | | | | Joined: Sep 2017 Posts: 135 Shop Shark | | Shop Shark Joined: Sep 2017 Posts: 135 | The older horns will pull more amps than the newer ones. Just make sure your harness can handle it during "Road Rage" or when you are driving behind my very close relative (Wife). LOL My 55 horn has aprox #14 wire on it, haven't looked at the newer vehicles for that. If you have a smaller wire feeding your horn and you use it a lot , you may need a bigger feed wire to keep it from melting. But for the short "toot toot" i would use it for, probably wouldn't bother it. Just my opinion, not necessarily fact, I've never done it. Though it does sound like a good idea.
| | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | Heck, I've used 6-volt horns on 12-volt trucks. Horns are intermittent use, so they can tolerate a lot of current mismatch.
1951 Chevy Panel Truck
