13 members (Otto Skorzeny, Gdads51, TUTS 59, Jon G, Joe H, HandyAndy, greenie-reddy, Simso, 1955 1 Series, Southerntruck, Gib70, 3B, 1 invisible), 123 guests, and 1 robot.
Topics128,103
Posts1,056,183
Members48,436
#1272412 07/14/2018 2:07 AM
Ok. So I've got a negative ground system. Tell me if this should work.
1. Batt to relay
2. Single wire off the steering column to relay
3. Wire from relay to horn.
4. Horn grounded to frame.
I tried this and it doesn't work. If I run the switch wire on the relay to the positive post, I can hear the relay click. Horn only sounds if I cross the switch wire and the negative from the battery directly the positive post.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
What kind of horn?
Klaxon oooogha.
I figured it out though. The relay chassis needs to be grounded. Works like a champ now!
