3 members (Nick in Manitou, Hotrod Lincoln, Shaffer's1950), 119 guests, and 1 robot.
Topics128,126
Posts1,056,354
Members48,441
Does a stock chassis need lubrication every 1000 miles, or can you go a few 1000 miles more since highways have come a long ways in the last 60 years? Just wondering.
Brian
1955.2 3100 Truck
"Does a stock chassis need lubrication every 1000 miles,
or
can you go a few 1000 miles more since highways have come a long ways in the last 60 years?"
Maybe yes,
or,
maybe yes.
I do it it every couple thousand miles, or, every year in the early Spring. It takes about 15 minutes by me, or by a good Shop. Most Shops do not know the grease points, especially brake pedal shaft.
http://chevy.oldcarmanualproject.com/shop/1954truck/54ctsm0009.html
I grease mine once a year also. I put about 2000-2500 miles a year on it. I also have a grease point on my clutch pedal shaft.
Brian
1955.2 3100 Truck
Your kingpins will thank you if you do it every 1,000 miles.
