1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#127124 07/02/2007 11:43 PM
Junior Member
Junior Member
ok my chevy needs alot of lower cab work such as door hinges rockers floor boards inner cowl and out cowl cab corners ect. i live on the east coast so i cant find a good cab laying around what order should i replace the cab parts ... i looks to me like there is a order i should replace things in so life is easyer .. thanks derek
#127125 07/04/2007 2:22 PM
Thats a real good Q. I just got my Cab corners from Classic..And it looks to me the rockers go in first..then the cab corners feed into the rocker. If you are going to replace the inside step plate and rocker.. Classic has a step plate rocker combo that I am going to order cause they are already welded together. I may be incorrect..but that is the way it looks to me..Rocker and step plate then cab corners. Some say take the door off,some say keep the door on. If you keep the door on you will be able to see if the step and rocker replacments are lining up correctly. I also read down the line,and in a how to do cab corner replacement that to leave the inner cab corners out..dont replace them..The body man doing the work said the inner cab corner is what caused the problem to begin with..(rot trapping sand) ect..I will look for the site that had a step by step proceedure on cab corner replacement if you want. M/G Port Washington? Were is that?
HURRY UP AND WAIT 55 235 3/4
#127126 07/04/2007 4:59 PM
Junior Member
Junior Member
yea sounds good portwashington is in longisland newyork
#127127 07/04/2007 9:57 PM
Check you e-mail, I sent some info from a website. Step bt step..Its pretty good
#127128 07/04/2007 10:23 PM
First off....
Happy Fourth Everyone !
mazdabon2nd,
Good to see another "islander" on here,especially one with a 1 Ton like me
Hey Mike G.
Which site are you refering to?
I would like a copy too if possible.
Regards,
#127129 07/04/2007 11:05 PM
Check your e-mail Steve// I think its called brothers trucks
#127130 07/04/2007 11:58 PM
Thanks Mike !
Good stuff
Regards,
#127131 07/05/2007 1:43 AM
Ter Offline
Sounds good to me too... could I have that web site ?.... or maybe post it here for all to see.
Ter
#127132 07/05/2007 1:28 PM
http://www.brotherstrucks.com/techa...NER+PATCH+PANEL+INSTALLATION&index=1
Let me know if this works..I am not to good at pasting Ter. if you cant access it I will e-mail it to you. M/G
#127133 07/15/2007 11:26 AM
When you actually start, do the passenger side first. That way, if you don't do the "perfect job", at least you won't have to look at it every time you get in the truck. (I learned this the hard way.)
[b]1957 Chevy Big Window 3100[.b]
More pix in Picasa
It ain't broke 'til you can't fix it any more.
