9 members (Wayne67vert, DaveV, Phak1, Eisenholtz, Ponchogl, Bill Hanlon, 55shaker, Rusty Rod, TUTS 59), 159 guests, and 1 robot.
Topics128,049
Posts1,055,546
Members48,425
Hi.Can any one recommend an electronic ignition for a 265 V8 chevy small block please.Also are they difficult to fit and set up?
Just use an original equipment Delco HEI from an early to mid 1980's Chevy 350. Be sure to use the one with a vacuum advance, not the one with the 4-wire electronic advance plug on it. It's a drop-in fit other than needing to run a 12 gauge or larger wire from the ignition switch to the HEI. RUN- - - -do not walk away from the Pertronix or other Rube Goldberg proprietary electronic systems.
On an early 265 V-8 is there a problem with the later distributor body and oiling if the correct distributor isn't used? My memory is pretty vague on this if it was just a one year problem with the 265.
Seems if the distributor wasn't correct or installed wrong it could block oil from reaching lifters.
Again I'm very vague on my memory of this, perhaps there is nothing to it.
That was a problem with the distributor, not the engine. If the 265 distributor housing was clocked incorrectly the flat spot on the housing didn't align with the passenger's side oil gallery. In about 1958, Chevy changed to a distributor with a full-circle groove in the housing instead of a flat spot so the orientation of the housing didn't matter.
Okay, make sense now. I couldn't remember just which it was. Thanks for clearing that up. smile
V
V Offline
Go to SpeedwayMotors.com they should be able to help you.
I have a 1945 GMC 228 engine 6 volts positive ground and I purchased a electronic ignition from them plus a new coil. The make of the electronic ignition is Pertronix. Came with great instructions took less than an hour to convert.
Weemolly45
Above the 49th
Stooby, if you choose to ignore the good advise here and buy a Pertronix or other conversion set up be sure to get extra parts. Just sayin! secret
I have used Pertronix with great success. Follow their directions and use the right parts and you will be fine. Some of the units I've put in are 10 years old now and still doing fine.
Nothing wrong with a Pertronix set up.
As I have posted many times: I have used a 6v (and, 12v) Pertronix on two of my trucks for many years with no problems.
Make sure your carburetor distributor is well-grounded (grease where the distributor enters the block might make a bad ground). Run a ground wire from coil-to-head-bolt to a distributor clip bolt. Clean attachment points to shiny metal and coat with conductive copper-impregnated grease. My belief is that a bad ground is the main culprit in Pertronix failures/performance/misses.
Nonetheless, I see no better performance/starting, and I now use points/condenser in the truck I should be restoring.
With or without the Pertronix unit , I carry a spare tested distributor on long trips.
Last edited by tclederman; 07/05/2018 4:09 PM. Reason: corrected serious/humorous mistake
Or use HEI and just throw it and run it. Mine still uses the original module from 1978 and I have carried the same spare module in all my cars with HEI since I started driving in 1970's, still haven't needed to install it yet!
Tim, how does grounding the carburetor help the ignition system work right? "Inquiring minds want to know!"
Jerry, it’s a special carb/dizzy combo. Only available for 1 year and only in NC.🤓
I meant distributor being grounded - oops
My grounding-screw instructions were at least correct, I hope?
V
V Offline
Oh man, and here I thought a well grounded carb was good for an engine. LOL. Course if you run an electric choke it is.
Don't scoff. My Quadrajet is grounded for the automatic choke. (Its actually a E-clone of a Carter AFB, but I am trying not to lose any more friends).
