6 members (walter74, Hotrod Lincoln, mason86, 55shaker, Otto Skorzeny, dt235sd), 72 guests, and 1 robot.
Topics128,050
Posts1,055,684
#1271113 07/03/2018 10:09 PM
Y
Y Offline
After much searching I haven't seen anyone post about how to replace these door latch springs. It appears the original spring is locked in there pretty good, maybe welded in the middle? Further once I get it off will this new one compress and spin around to look the same mount? Thanks.
Right above this thread you will see the Doors Forum. There are several threads addressing this issue there. Good luck.
It is a strong spring. The center just slip fits in the slotted shaft. I put the works in a vice and use vice grips to twist the outer tang of the spring over where it goes. You can't get a full bite on the spring end and get it to go on. Grabbing a corner of the tag end of the spring at a 45 degree angle with the vice grips works after a try or two.
Carl
