3 members (klhansen, ronsway, 1 invisible),
165
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 127 | Unfortunately its time for an overhaul on my stock 216. Before I struggle, I'm trying to figure out if I can pull the engine without the trans, or do I have to pull it as one unit? There's a lot of grime to clean off, so I can't tell if all the bolts are accessible or not, but I thought I remembered hearing that it had to come as a unit. Thanks for the help! | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | The whole front clip is easily removed with the removal of a few bolts which makes engine removal much easier. On my '47.1 series GMC there were a few bolts that were difficult to reassemble by myself, which I replaced with studs for ease of one person reassembly.
Ed
| | | | | Joined: Aug 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 127 | Thanks for the response, but it didn't actually answer my question... Can the engine be removed without removing the transmission? Or, I suppose, can the trans be removed without removing the engine? To clarify, I know myself and there is work to be done on my fenders and grill, if I remove them there is a 99% chance that I'll have to fix them before I remount them. I just want the truck back on the road, I was really hoping to avoid opening pandoras box.
| | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | I was able to pull my 46 2-ton engine with the transmission and without pulling anything but the hood, radiator core and shifter. I would caution against pulling any more sheet metal than necessary. You will probably break a few bolts and that can be a pain to deal with. Getting one of these is a life saver for pulling engines. https://mossmotors.com/tilt-lift-engine-hoistI have had one for years and won't pull an engine without one. You can stand it up from end to end. | | | | | Joined: Feb 2016 Posts: 1,989 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,989 | I had to separate the engine and trans before the engine could be removed. My truck is a Low Cab Forward and the front floor support would not allow the combination to come out in one pull.
| | | | | Joined: Jun 2018 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 46 | I was able to pull my 46 2-ton engine with the transmission and without pulling anything but the hood, radiator core and shifter. I would caution against pulling any more sheet metal than necessary. You will probably break a few bolts and that can be a pain to deal with. Getting one of these is a life saver for pulling engines. https://mossmotors.com/tilt-lift-engine-hoistI have had one for years and won't pull an engine without one. You can stand it up from end to end. Slick item, added to my wannaget list...
Stuff I’m gonna work on, I swear 1963 C30 flatbed 1961 Apache 30 (parts, no title) 1960 GMC Big Bolt
Don't tweet, face, Google, or link. Just hanging in as long as I can...
