0 members (), 162 guests, and 4 robots.
Topics128,089
Posts1,056,139
Members48,435
#1271054 07/03/2018 12:11 PM
Unfortunately its time for an overhaul on my stock 216. Before I struggle, I'm trying to figure out if I can pull the engine without the trans, or do I have to pull it as one unit? There's a lot of grime to clean off, so I can't tell if all the bolts are accessible or not, but I thought I remembered hearing that it had to come as a unit. Thanks for the help!
Crusing in the Passing Lane
The whole front clip is easily removed with the removal of a few bolts which makes engine removal much easier. On my '47.1 series GMC there were a few bolts that were difficult to reassemble by myself, which I replaced with studs for ease of one person reassembly.
Ed
Thanks for the response, but it didn't actually answer my question... Can the engine be removed without removing the transmission? Or, I suppose, can the trans be removed without removing the engine? To clarify, I know myself and there is work to be done on my fenders and grill, if I remove them there is a 99% chance that I'll have to fix them before I remount them. I just want the truck back on the road, I was really hoping to avoid opening pandoras box.
I was able to pull my 46 2-ton engine with the transmission and without pulling anything but the hood, radiator core and shifter. I would caution against pulling any more sheet metal than necessary. You will probably break a few bolts and that can be a pain to deal with. Getting one of these is a life saver for pulling engines.
https://mossmotors.com/tilt-lift-engine-hoist
I have had one for years and won't pull an engine without one. You can stand it up from end to end.
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
7
7 Offline
I had to separate the engine and trans before the engine could be removed. My truck is a Low Cab Forward and the front floor support would not allow the combination to come out in one pull.
Slick item, added to my wannaget list...
Stuff I’m gonna work on, I swear
1963 C30 flatbed
1961 Apache 30 (parts, no title)
1960 GMC Big Bolt
Don't tweet, face, Google, or link. Just hanging in as long as I can...
