4 members (wilbur53, klhansen, Steelonsteel, Bill Hanlon), 141 guests, and 2 robots.
Topics128,266
Posts1,058,368
Members48,485
#127092 07/01/2007 2:08 PM
I have the cab on my 46 down to bare metal and was wondering what the product is that you see them use when putting a real smooth finish on the body. The roof and the back of my cab are full of pin holes and obviously can't prime and paint over this and expect a smooth finish as I will be applying a top clear coat. One body shop person I talked to said theres a 2 part putty on the market that spreads like cream and then you sand it down just about to the metal. Can anyone elabarate on this. Thanks Bob T
#127093 07/01/2007 2:19 PM
if the metal is indeed full of "pinholes" the product you want is a welder .... if there's minor pitting that can't be leveled with normal sanding, there are a variety of fillers [genericly called body putty or 'bondo'] and spot puttys available, check local auto parts places that have body shop supplies
#127094 07/01/2007 9:53 PM
red58 is right, bondo won't cure yer pinholes..either a wire feed welder or a torch with either brass or steel rod..I've found that brass vis the easiest fer pinholes...
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
#127095 07/01/2007 11:37 PM
If you're dealing with pits rather than pin holes, there's a product at O'Reilly's called Putty Kote that works well. It's smoother and easier to sand than Bondo.
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
#127096 07/01/2007 11:51 PM
Theres also a product called "frosting" thats real good for filling minor scratches,pinholes,etc....
It goes on smooth and sands real easy.
Marty
#127097 07/02/2007 4:44 AM
my local body man is doin my doors as we speak ...an he used lead too fill the few tiny pinholes in my doors where the seal lays against the bottom edge inside to seal against the rocker ...they look great !
1952 Chevy Shortbed
Photos in Photobucket
#127098 07/02/2007 2:12 PM
Thanks very much for the info. I think I'm going to go with the putty as it's not just pinholes but the whole surface is pitted and rough. To lead or weld a complete surface would be a little tedious and might cause warpage of the sheet metal. I believe Boyd Coddingtons body crew apply it to the whole surface of his vehicles and they sand down to the surface to give it a nice smooth finish prior to primer and paint. thanks again for the info. Bob T
#127099 07/03/2007 1:35 AM
A skim coat of filler would take care of it. And it will take care of any uneven body panels too.
Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now.
http://www.coxcustomcars.com/
#127100 07/03/2007 2:45 AM
Make sure you get all of the rust out of the holes first. The filler won't stay in if there's rust present, plus, it'll rust further inder the filler. I'll also second the Putty Coat filler. Good stuff. it's made by the same people who make Bondo, RPM/Dynatron, but is a more professional product. Well worth the extra cost, which isn't really that much.
Bill Burmeister
#127101 07/03/2007 9:37 AM
there are finish fillers for the top coat that makes it very easy for a smooth finish sence you have holes i would use a filler that has fiberglass first then follow up with a finish top coat just like frosting a cakes when sanding if you brake into the fiberglass filler stop youve gone to far put another top coat on practace makes perfect you want to keep the metal completly sealed
#127102 07/06/2007 2:59 AM
If its pitting from surface rust, use a body filler like Rage or a putty/frosting , but I can think of any names.
Eric
http://s1199.photobucket.com/user/sparky234/library/My%2057%20Chevy%20Stepside?sort=3&page=1
'57 Chevy 3100 (Little Red)
'81 RD350 LC - Fun, Fun, Fun
'83 GS1100E - Pocket Rocket
#127103 07/15/2007 11:21 AM
I think this is what you're looking for - Metal Glaze
http://www.eastwoodco.com/jump.jsp?itemID=11052&itemType=PRODUCT
[b]1957 Chevy Big Window 3100[.b]
More pix in Picasa
It ain't broke 'til you can't fix it any more.
#127104 07/15/2007 8:28 PM
Thanks for all the info guys, I got a can of Bondo finishing glaze and it filled in all the pin holes on the roof. Spread real nice like a cream and now only time will tell when I prime and paint. Appreciate all the info so thanks again. bob T
