| | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | I have the cab on my 46 down to bare metal and was wondering what the product is that you see them use when putting a real smooth finish on the body. The roof and the back of my cab are full of pin holes and obviously can't prime and paint over this and expect a smooth finish as I will be applying a top clear coat. One body shop person I talked to said theres a 2 part putty on the market that spreads like cream and then you sand it down just about to the metal. Can anyone elabarate on this. Thanks Bob T | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if the metal is indeed full of "pinholes" the product you want is a welder .... if there's minor pitting that can't be leveled with normal sanding, there are a variety of fillers [genericly called body putty or 'bondo'] and spot puttys available, check local auto parts places that have body shop supplies
Bill | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | red58 is right, bondo won't cure yer pinholes..either a wire feed welder or a torch with either brass or steel rod..I've found that brass vis the easiest fer pinholes...
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | If you're dealing with pits rather than pin holes, there's a product at O'Reilly's called Putty Kote that works well. It's smoother and easier to sand than Bondo.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Theres also a product called "frosting" thats real good for filling minor scratches,pinholes,etc.... It goes on smooth and sands real easy. Marty | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | my local body man is doin my doors as we speak ...an he used lead too fill the few tiny pinholes in my doors where the seal lays against the bottom edge inside to seal against the rocker ...they look great ! | | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | Thanks very much for the info. I think I'm going to go with the putty as it's not just pinholes but the whole surface is pitted and rough. To lead or weld a complete surface would be a little tedious and might cause warpage of the sheet metal. I believe Boyd Coddingtons body crew apply it to the whole surface of his vehicles and they sand down to the surface to give it a nice smooth finish prior to primer and paint. thanks again for the info. Bob T | | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | A skim coat of filler would take care of it. And it will take care of any uneven body panels too. Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Make sure you get all of the rust out of the holes first. The filler won't stay in if there's rust present, plus, it'll rust further inder the filler. I'll also second the Putty Coat filler. Good stuff. it's made by the same people who make Bondo, RPM/Dynatron, but is a more professional product. Well worth the extra cost, which isn't really that much.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | there are finish fillers for the top coat that makes it very easy for a smooth finish sence you have holes i would use a filler that has fiberglass first then follow up with a finish top coat just like frosting a cakes when sanding if you brake into the fiberglass filler stop youve gone to far put another top coat on practace makes perfect you want to keep the metal completly sealed | | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | If its pitting from surface rust, use a body filler like Rage or a putty/frosting , but I can think of any names. | | | | | Joined: Oct 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 119 | | | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | Thanks for all the info guys, I got a can of Bondo finishing glaze and it filled in all the pin holes on the roof. Spread real nice like a cream and now only time will tell when I prime and paint. Appreciate all the info so thanks again. bob T | | |
