0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 96 Shop Shark | | Shop Shark Joined: Apr 2016 Posts: 96 | This may be a post for the driveline section, but I figured because it specific to bigger trucks it would fit here. I pulled the PTO off of my truck because it was leaking. I searched all of the numbers on it but I can't figure out what it is. I would like to order a seal kit for it so i can put it back on. Does anyone know what I have? [img]http://i.imgur.com/vwMmRNf.jpg[/img][img]http://i.imgur.com/BijrCZg.jpg[/img]
1954 GMC 350-27
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy AdamK1500, PTO identification has always been a mystery to me, what with all the different companies merging or going out of business. There is a code or system to their numbering at least for some of them, things like torque capability, type of shift, direction of rotation etc.. What I have done in the past is measure the shaft diameter and the housing seal bore and order a seal, some of those seals have been a rather unique shape. I'll see if I can locate some numbers. | | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | When I had mine off, I was able to get the # off the seals and found some replacements on Ebay. | | | | | Joined: Apr 2016 Posts: 96 Shop Shark | | Shop Shark Joined: Apr 2016 Posts: 96 | I'll pull the seals this weekend and see if I can find any numbers on them.
Thanks for the help!
1954 GMC 350-27
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Seals are usually obtained by dimension. PTO's are usually ID'd by transmission, since tooth count, pitch, depth are different for each trans.
Ed
| | | | | Joined: Apr 2016 Posts: 96 Shop Shark | | Shop Shark Joined: Apr 2016 Posts: 96 | I got the seals out and measured. Just for reference for anyone looking, motion industries has a pretty large selection of oil seals to pick from.
1954 GMC 350-27
| | | | | Joined: Jun 2018 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 46 | Since the dump bed was removed on mine but the the hoses going nowhere I gues I should pull mine off and start cleaning it up. May as well pick up a parts cleaner from the cheap import store, I have a least that much grease on mine.
Stuff I’m gonna work on, I swear 1963 C30 flatbed 1961 Apache 30 (parts, no title) 1960 GMC Big Bolt
Don't tweet, face, Google, or link. Just hanging in as long as I can...
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If one takes off a PTO, it is always a good idea to mark what trans it came off, otherwise it will become useless, someone else might want to use it someday.
Ed
