0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1269891 06/22/2018 1:37 PM
This may be a post for the driveline section, but I figured because it specific to bigger trucks it would fit here.
I pulled the PTO off of my truck because it was leaking. I searched all of the numbers on it but I can't figure out what it is. I would like to order a seal kit for it so i can put it back on. Does anyone know what I have?
[img]http://i.imgur.com/vwMmRNf.jpg[/img]
[img]http://i.imgur.com/BijrCZg.jpg[/img]
1954 GMC 350-27
3B Offline
Hy AdamK1500, PTO identification has always been a mystery to me, what with all the different companies merging or going out of business. There is a code or system to their numbering at least for some of them, things like torque capability, type of shift, direction of rotation etc.. What I have done in the past is measure the shaft diameter and the housing seal bore and order a seal, some of those seals have been a rather unique shape. I'll see if I can locate some numbers.
Big Bolt Forum Moderator
When I had mine off, I was able to get the # off the seals and found some replacements on Ebay.
Mike
I'll pull the seals this weekend and see if I can find any numbers on them.
Thanks for the help!
1954 GMC 350-27
Crusing in the Passing Lane
Seals are usually obtained by dimension. PTO's are usually ID'd by transmission, since tooth count, pitch, depth are different for each trans.
Ed
I got the seals out and measured. Just for reference for anyone looking, motion industries has a pretty large selection of oil seals to pick from.
1954 GMC 350-27
Since the dump bed was removed on mine but the the hoses going nowhere I gues I should pull mine off and start cleaning it up. May as well pick up a parts cleaner from the cheap import store, I have a least that much grease on mine.
Stuff I’m gonna work on, I swear
1963 C30 flatbed
1961 Apache 30 (parts, no title)
1960 GMC Big Bolt
Don't tweet, face, Google, or link. Just hanging in as long as I can...
If one takes off a PTO, it is always a good idea to mark what trans it came off, otherwise it will become useless, someone else might want to use it someday.
Ed
