2 members (homer52, Tronman), 239 guests, and 6 robots.
Topics128,077
Posts1,056,033
Members48,433
#126969 06/27/2007 9:31 PM
V
V Offline
I've got the hood back on the truck but I'm not to sure about the gap between the hood and cab. Please look at this picture: http://rides.webshots.com/photo/2104980810080243953WGvuZq and give your best advice. It seems there is too much of a gap but it looks like some others I've seen here. What about the contact with the hood seal? It just doesn't seem right either. I've learned from you all many times so here I am asking once again. Thanks
#126970 06/27/2007 11:44 PM
That looks way too far forward to me. Theres adjustment "slop" built into the bolt holes.
Loosen em up a bit and wiggle it around till it looks right.
Good Luck,
Marty
#126971 06/28/2007 1:29 AM
I'm not sure anyone has come up with an exact science for aligning these things. To me I would say somethings wrong if one actually DID line up right. grin
Keith
If it were easy they'd have grade schoolers doing it!
#126972 09/27/2007 8:56 PM
Junior Member
Junior Member
I was having the same problems with the hood & fender alinement on my 48.
Then I read over the 48-51 shop manual once again , & did as the book said to do I moved & added shims.
Now the Hood sits close to the cowel & tight to the weatherstriping also there is a lot less gap between the hood & fenders.
Orin
harley
#126973 09/27/2007 9:37 PM
I fought with the hood on my 54 truck..had an inch gap at the cowl.....finally figured out that it is a 3 person job! My hood now fits nice and tight at the cowl and fenders.
1. Loosen the 3 bolts on each side of the hood..one in the engine compartment, 2 on the inside. You don't need to remove the glove box.
2. Put a 4 inch block under the front hood latch pin, propping up the hood.
3. Helpers 1&2, one on each side of the hood at the cowl, pressing down and back with the flats of both hands.
4. #3 person snugs down the inside bolts. (2) on each side.
5. Raise the hood, tighten the remaining loose bolt on each hinge, and gently close the hood, checking for alignment.
6. To get the fenders/hood gaps even I adjusted the 3/8" firewall/core-support rods.
Hope this helps.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#126974 09/27/2007 10:05 PM
Dave,
Thanks. I am going to give your instructions a try (I've given up on other instructions).
Tim
#126975 09/27/2007 10:33 PM
V
V Offline
I've removed the hood to pull the motor so I'll try Dave's instruction too when it is time to put it back on! Thanks.
