1 members (RLB),
215
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I've got the hood back on the truck but I'm not to sure about the gap between the hood and cab. Please look at this picture: http://rides.webshots.com/photo/2104980810080243953WGvuZq and give your best advice. It seems there is too much of a gap but it looks like some others I've seen here. What about the contact with the hood seal? It just doesn't seem right either. I've learned from you all many times so here I am asking once again. Thanks Bill | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | That looks way too far forward to me. Theres adjustment "slop" built into the bolt holes. Loosen em up a bit and wiggle it around till it looks right. Good Luck, Marty | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | I'm not sure anyone has come up with an exact science for aligning these things. To me I would say somethings wrong if one actually DID line up right.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Sep 2007 Posts: 2 Junior Member | | Junior Member Joined: Sep 2007 Posts: 2 | I was having the same problems with the hood & fender alinement on my 48.
Then I read over the 48-51 shop manual once again , & did as the book said to do I moved & added shims.
Now the Hood sits close to the cowel & tight to the weatherstriping also there is a lot less gap between the hood & fenders.
Orin
harley
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I fought with the hood on my 54 truck..had an inch gap at the cowl.....finally figured out that it is a 3 person job! My hood now fits nice and tight at the cowl and fenders.
1. Loosen the 3 bolts on each side of the hood..one in the engine compartment, 2 on the inside. You don't need to remove the glove box.
2. Put a 4 inch block under the front hood latch pin, propping up the hood.
3. Helpers 1&2, one on each side of the hood at the cowl, pressing down and back with the flats of both hands.
4. #3 person snugs down the inside bolts. (2) on each side.
5. Raise the hood, tighten the remaining loose bolt on each hinge, and gently close the hood, checking for alignment.
6. To get the fenders/hood gaps even I adjusted the 3/8" firewall/core-support rods.
Hope this helps.
Dave | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Dave,
Thanks. I am going to give your instructions a try (I've given up on other instructions).
Tim | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I've removed the hood to pull the motor so I'll try Dave's instruction too when it is time to put it back on! Thanks. | | |
