1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 55 | What is the correct placement of the pinstripe or is it stock,on the "46"?
b51r
b51r
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I believe there was a single stripe about 1/8" centered on the belt line. I've seen factory info on the subject within some of the online listing of factory paint info. Check the tech tip info on this site also use the search feature. | | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | I believe too that the info from JiMerit is correct. The pinstripe runs around the cab and hood belt moulding. Jim Carter mentions the pinstripe colors and sells pinstriping kits. I have seen it mentioned elsewhere but cannot locate the source right now. Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Oct 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 55 | Thank you for the replies.
b51r
b51r
