1 members (78buckshot),
112
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Big truck fenders are available from other donor trucks. Ebay and CL will also have them. I have not seen the fenders reproed. Not a show stopper. Same with extensions and running boards. You have a 64-66 cab by the looks of the windshield and vent window. Not a problem, but interesting. Cant help with the crane, but it sure is cool. | | | | | Joined: Jul 2004 Posts: 2,988 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,988 | Cool truck! As mentioned, you'll probably have look for a donor truck or check salvage yards. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Google the crane/ladder company-tel.... That info should help there, the phone number is even there. One could buy a whole truck for the cab only for somewhere not in the rust belt.
Wash off the weeds and get started. Looks like a lift/ladder job for working on what one lifts-telephones, signs, billboards, etc.
Ed
| | | | | Joined: May 2015 Posts: 11,078 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,078 | This outfit Terex is the successor to Tel-e-lect Products Co. At least that's what my quicky search tells me. They may be able to help out with info on the crane.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2010 Posts: 97 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 97 | This outfit Terex is the successor to Tel-e-lect Products Co. At least that's what my quicky search tells me. They may be able to help out with info on the crane. Agreed. It definitely looks like a rig for handling utility poles. Their tech support page is https://www.terex.com/utilities/en/service-support/technical-service-support/index.htm Based on the info there, you should be able to quote the info on your data tag (Tel-Econ Model 10A, serial 1152 and ask what they can provide to help you restore/maintain the equipment to be safe. The safety requirement might include them having to make data plates for controls and load limits available (maybe expensive to get singles made). It never hurts to ask. | | | | | Joined: May 2015 Posts: 11,078 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,078 | The safety requirement might include them having to make data plates for controls and load limits available (maybe expensive to get singles made). It never hurts to ask. Agree that making a new metal data plate might be costly, but today most stuff uses vinyl stick-on labels, and one-offs aren't that expensive to print.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I've never seen a utility company use a truck like that (to light duty for them)...but have seen sign company's use that same set-up. Back in the 50's & 60's there were tons of gas station and stores with neon signs less than 20' off the ground and rigs like this would be used to set and service them. Mike B  | | | | | Joined: Feb 2016 Posts: 114 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 114 | Thanks guys! I hope Terex is willing to work with me, my experience is company buyouts/mergers results in orphan equipment, but I can always be optimistic! I did find some other trucks for parts, but the fenders are likewise rusty, I was hoping to not have to deal with it... oh well, another learning experience, right?
I agree with the sign company thought, there is one of those magnetic mats with the name of a sign company on it in the tool box, and the seller told me a sign company sold it off to him. They took the auger, though. Would that be a common enough thing to get a hold of? All of my searches kept bringing up skid loader mounts, pretty pointless (and expensive) to buy one, and rip it apart immediately.
The brakes don't work either (surprising, right?). The PO said it is the power booster, but when I depressed the pedal, there was no resistance, and it squirted fluid the entire pedal travel. I only have experience with the 58-59 style master, is this normal for these? Or did my master cylinder croak? | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | On a truck as old as this one you want to replace/rebuild ALL of the brake system components, this includes new steel and rubber lines...they fail from the inside out. The shoes and drums might be OK. While you have the drums off this would be a good time to check and repack the bearings and replace the grease seals. Mike B  | | | | | Joined: Feb 2016 Posts: 114 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 114 | Oh, I know, I'm just trying to get it to limp around the yard for a bit, then I'll tear the brakes apart, and replace the lines with stainless tubing. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Cu-N lines are easy to work with, many flaps carry them.
Ed
| | | | | Joined: Feb 2016 Posts: 114 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 114 | Pardon my ignorance, what's a "flap"? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Friendly local auto parts store.ðŸ›
| | | | | Joined: Apr 2017 Posts: 93 Shop Shark | | Shop Shark Joined: Apr 2017 Posts: 93 | Sweet truck, I always loved old crane trucks. Good luck with it. | | | | | Joined: Apr 2018 Posts: 11 New Guy | | New Guy Joined: Apr 2018 Posts: 11 | If you can get the measurements of the wheel cylinders you may be able to buy wheel cylinder rebuild kits (they contain 2 cups and a spring for each wheel cylinder) the cost of these kits is usually about $5.00 if you can find them. Be sure to verify that the bleeder screws will come out first and once the kits are acquired get a small hone to hone the bore. Wash the inside clean with brake fluid after honing. In most cases the wheel cylinders can be rebuilt still mounted to the backing plate. I suggest a healthy dose of PB Blaster on the bleeder screws long before you attempt to loosen them. You may also be able to find a master cylinder rebuild kit as well.
Don't fear the competition, BE the competition
| | | | | Joined: Feb 2016 Posts: 114 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 114 | I got the master cylinder working, turns out it only needed cleaned. I took a look at the rear axle, and I got cock eyed twinplexes. Anyone got a foolproof method to bleeding these? I just got off from bleeding my viking, and my approach (take it apart, bleed, reassemble) left a lot to be desired. | | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | I'm pretty sure I have fenders for your truck stashed in the barn. How far does the flare stick out form the fender? I recently found out that shipping through Fastenal is super cheap. | | | | | Joined: Feb 2016 Posts: 114 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 114 | The flare stands out about 3.5 inches from the fender. I also ran into a new problem on another truck. The tee that passes through the frame to connect the hydrovac to the rest of the brake lines gave out, is there a part number so I can get a new one? | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Casey, You should always start a new thread when you ask a new question about as different truck, it makes it easier for the next guy to search. Start a new thread and tell us what year, make and model are you asking about? Mike B  | | | | | Joined: Feb 2016 Posts: 114 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 114 | I got the truck running pretty smoothly, but the air filter seems to have a leak at a seam, the oil level is far too low (1/3 full) for the 45 minutes I had it idling. Were these filters prone to issues? Should I try to fix it, and where? Or is a paper element more in line? | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Oil bath not hard to find in junk yard. Or you can very easily use a paper filter breather that fits the carb. Or search the site for how to modify your oil bath canister to use a paper filter. | | |
