3 members (2-Ton, 1955 1 Series, Phak1), 126 guests, and 2 robots.
Topics128,091
Posts1,056,449
Members48,443
1964 c-10. Removed the six and installing a 1994 350. I'd like to retain the original 3 speed column shift for now. I know its 168 teeth and came with a 10 inch clutch. Is there room to upsize (ex. bell housing clearance) and if so, any preferences on a clutch/flywheel combo that will match up to the V-8? Thanks so much!
V-8 trucks of that era would have had an 11" clutch and used the same bellhousing as the 6 cyl. Since you will need a different flywheel for the later engine as it has a different size bolt pattern on the mounting flange, purchase one that uses the 11" clutch. Get a clutch kit for the year of the truck with a V-8.
Fred
